SomeNew Name Posted September 15, 2006 Share Posted September 15, 2006 Hi, I'm new here and a new owner of a very rusty 1990 Comanche, it is very difficult for me to crawl under my truck as I have some knee problems and I would like to remove the bed from my truck as I can gain better access to the frame rails in the rear. Would some be so kind as to post a few pictures as to where these 8 bolts are located, and other locations of interest (ie: Parking brake cable mounting points on the bed, even a good suggestion as to how to suport both the gas tank and the cables during removal would help as well) as it would save me time trying to crawl around underneath. Or even a very Detailed description as to where they are located. I under stand that this is a rather idiotic request but mobility is a factor for me and the less time I spend on my knees in pain the better. Me and My knees thank you in advance for your kindness. Eugene P.S it is a short box if that helps also. I know that 4 of the bolts are located in the green areas and that the gas tank and the parking brake wire-bracket are mounted in relativley the same location as depicted. could some one take this picture and circle the remaining 4 bolts please. thank you Link to comment Share on other sites More sharing options...
SomeNew Name Posted September 15, 2006 Author Share Posted September 15, 2006 That would look better. sorry I'm not very good with forums. Link to comment Share on other sites More sharing options...
jeepthing07 Posted September 16, 2006 Share Posted September 16, 2006 I circled the other 4 locations in red the bolts are 15mm, theres a good chance of snaping bolts off in the bed if its really rusty Image Not Found there is only 3 bolts holding the parking brake bracket to the bed. you will need to take out the screws that mount the gas filler to the bed, loosen up the J-bolts that hold the gas tank to the bed then you can just push the tank up and unhook them (run most of the gas out first). unhook all the plastic clips that the taillight wire runs through under the bed. and remove the tailgate Link to comment Share on other sites More sharing options...
bdjr Posted September 16, 2006 Share Posted September 16, 2006 where did you get your fuel cell? and how much was it? is it comanche specific? found a pinhole leak in mine that rotted the bed out. bill Link to comment Share on other sites More sharing options...
SomeNew Name Posted September 16, 2006 Author Share Posted September 16, 2006 Ohh this is not a picture of my truck. it is a picture that I found here on the forum. But the owner had this write up about it "Very simple design, made of 3 mm stainless steel plates and tig welded. I just adjusted the tank sending unit and made a new gasket around the fuelpump, otherwise it works good." http://comancheclub.com/forums/viewtopic.php?t=169 If you would like to see the thread itself. Link to comment Share on other sites More sharing options...
dfreeman616 Posted December 5, 2006 Share Posted December 5, 2006 so how long are the bolts for mounting the bed? i'm looking at getting a comanche that currently has the bed on it, but not bolted down, so i want to bring a few to attach it when i pick it up. Link to comment Share on other sites More sharing options...
pingpong Posted December 5, 2006 Share Posted December 5, 2006 They forgot to tall you about the grounding strap located in the drivers side taillight bucket area. I can't tell you how long mine were... most of them broke off when I was taking them off Link to comment Share on other sites More sharing options...
dfreeman616 Posted December 7, 2006 Share Posted December 7, 2006 do they bolt into something, or do they have nuts on them? Link to comment Share on other sites More sharing options...
