If the fusible link is burnt and I'm right that it also gives power to the fuel pump relay, and the fuel pump relay is still somehow attached to your fuel pump, you could have "fixed" the problem by back feeding power through from the ECU to the fuel pump, which probably isn't great for the ecu. If the ecu is even still doing something...
