exjay33 Posted June 15, 2008 Posted June 15, 2008 The temp sensor for new cluster is on the water neck correct , 2 wire weatherpack connector ? What I can find is part num. 53005056 for chrysler is this correct num. ? This is a 92 cluster in a 91 . Is there a certain year of I should get ?
BLHTAZ Posted June 15, 2008 Posted June 15, 2008 No...that is the one for the electric fan. The sensor for the cluster is on the left rear top corner of the head...
HOrnbrod Posted June 15, 2008 Posted June 15, 2008 No...that is the one for the electric fan. The sensor for the cluster is on the left rear top corner of the head... P/n 56027012 is the one you need. Maybe Taz can help you out?
johnnyc Posted June 15, 2008 Posted June 15, 2008 For some reason, Kragen calls it an "ignition temperature sender". Here's the part number. http://www.partsamerica.com/ProductDeta ... er=TS82771 Be very careful not to snap off the connector on the new one when installing it. I didn't break the new one. But I did break the old one when taking it off.
BLHTAZ Posted June 15, 2008 Posted June 15, 2008 No...that is the one for the electric fan. The sensor for the cluster is on the left rear top corner of the head... P/n 56027012 is the one you need. Maybe Taz can help you out? 56027012 = about $18 retail, but I can sell it for $11.50. You will still have a couple dollars additional for mailing it too, so it may be just as easy to get one at AZ or Discount...whatever you have around you. Let me know if I can help. :cheers:
exjay33 Posted June 16, 2008 Author Posted June 16, 2008 Mine is not located in that position could it be further out on the intake between 2 other lines?
exjay33 Posted June 16, 2008 Author Posted June 16, 2008 Never mine last post by me I found it hiding under a inch of crud , a little brake cleaner goes a long way . Thanks guys
Geonovast Posted June 17, 2008 Posted June 17, 2008 No...that is the one for the electric fan. The sensor for the cluster is on the left rear top corner of the head... So they DID use two different types of connectors for that. Both my trucks have the round connector but the sensor from my 92 4.0 in the shed had that square one.
BLHTAZ Posted June 17, 2008 Posted June 17, 2008 Just a qualification on that pic I posted... It is NOT my truck, but just a pic that I found on a quick Google search so I have no idea what year it is. ;)
88XJSport Posted June 17, 2008 Posted June 17, 2008 The connector in that pic is from a gauge cluster swap write up I saw a while back. That truck was a 96. http://www.opiebennett.com/Gauge.htm
BLHTAZ Posted June 17, 2008 Posted June 17, 2008 The connector in that pic is from a gauge cluster swap write up I saw a while back. That truck was a 96. http://www.opiebennett.com/Gauge.htm Yep...that's where I found it. :cheers:
