sensors for new gauge cluster
I have asked this before but no real answer . My question is when you install the new gauge cluster and change the oil pressure sensor the one for the idiot light has one wire the gauge has 2 wires where does the wire go , anyone know ? Also does the water temp sensor need changed?
The gauge has NO wires. The cluster with the gauges has a printed circuit board. ALL wiring is already set up for the gauges. Just replace the oil pressure sender and the water temperature sender and the cluster is otherwise plug-and-play.
If you got an oil pressure sender with two wires...you have the wrong one. The sender for the guage still has only one wire just like the switch for the light. I have done this swap too and it is very simple.
I guess I misread the intent of this post. I saw "the gauge has 2 wires" and posted an answer to that. Didn't realize you meant the sender had two wires. Sorry.
