Darren Posted June 7, 2008 Share Posted June 7, 2008 I've converted from the ba-10 to the ax-15. what do i have to do to get my transfercase shift linkage to line-up? Link to comment Share on other sites More sharing options...
skinut88 Posted June 7, 2008 Share Posted June 7, 2008 they don't bolt up there is i believe a 4 inch diffrence in the Zbar linkage. you best bet is to get the adapter plate from novak this is the one i used http://www.novak-adapt.com/catalog/kit_sk2x.htm or you could fab something up. :brows: Link to comment Share on other sites More sharing options...
Pete M Posted June 7, 2008 Share Posted June 7, 2008 This likely won't help your immediate issue, but while we're on the subject, this is the procedure for adjusting the stock linkage. Link to comment Share on other sites More sharing options...
Darren Posted June 9, 2008 Author Share Posted June 9, 2008 pete you did the swap right? how did you get it to work? Link to comment Share on other sites More sharing options...
Pete M Posted June 9, 2008 Share Posted June 9, 2008 I swapped in a 99 TJ AX-15/NP-231, so I'm not entire sure the bracketry would match yours, but I Bolted on a flat piece of steel to the new transmission and that gave me a new pivot point in space to match the one on the MJ's body. Link to comment Share on other sites More sharing options...
MiNi Beast Posted June 9, 2008 Share Posted June 9, 2008 they don't bolt up there is i believe a 4 inch diffrence in the Zbar linkage. you best bet is to get the adapter plate from novak this is the one i used http://www.novak-adapt.com/catalog/kit_sk2x.htm or you could fab something up. :brows: This here... http://www.novak-adapt.com/catalog/kit_sk2x.htm Thinking of this for myself as well. Link to comment Share on other sites More sharing options...
Motion Offroad Posted June 9, 2008 Share Posted June 9, 2008 Skyjacker also sells an adapter setup. They say it's for the TJ's; and we have not tried it yet on an XJ/MJ. So I unfortantly can't tell you if it does or does not work. I don't see why it wouldn't though.... A little bit cheaper option than the Novak kit. http://motionoffroad.com/catalog/index. ... cts_id=465 Link to comment Share on other sites More sharing options...
