fatcat0491 Posted May 27, 2008 Share Posted May 27, 2008 I'm in need of new shocks of the Manche anyways Where can i buy shocks also Can XJ Shocks work? Link to comment Share on other sites More sharing options...
pingpong Posted May 27, 2008 Share Posted May 27, 2008 XJ shocks can work up front, but not in the rear. I would suggest that you buy a set of bayonet elimantors for the front. This maked the front a hoop to hoop setup, which greatly increases your shock choices. They only cost about 30 bucks. Link to comment Share on other sites More sharing options...
fatcat0491 Posted May 27, 2008 Author Share Posted May 27, 2008 Shock wise i don't care as long as they are new Mine are rusted out :cry: Any direction of a set of fairly cheap Shocks all around? Link to comment Share on other sites More sharing options...
smartazz19 Posted May 27, 2008 Share Posted May 27, 2008 Why can't XJ shocks work in the rear? :huh???: I just put a set of 3" XJ shock front and rear of my comanche. Works just fine. They were a perfect fit for my 3" AALs. XJs have bar pins in the top mounting, just don't put the bar pin in the shock. Link to comment Share on other sites More sharing options...
TNT Posted May 27, 2008 Share Posted May 27, 2008 I suggest making new upper and lower mounts so you can run a longer shock. Here's a couple of Ideas. Image Not Found Image Not Found Image Not Found Image Not Found I have a ton more pictures, let me know if you need more ideas. :cheers: Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 27, 2008 Share Posted May 27, 2008 Why can't XJ shocks work in the rear? :huh???: I just put a set of 3" XJ shock front and rear of my comanche. Works just fine. They were a perfect fit for my 3" AALs. XJs have bar pins in the top mounting, just don't put the bar pin in the shock. There's a ton of shocks that will work on the MJ rear. I have a cross reference list in MSWord, but I can't post it, or can I? Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted May 27, 2008 Share Posted May 27, 2008 Why can't XJ shocks work in the rear? :huh???: I just put a set of 3" XJ shock front and rear of my comanche. Works just fine. They were a perfect fit for my 3" AALs. XJs have bar pins in the top mounting, just don't put the bar pin in the shock. XJ rear shocks are different than MJ shocks. Even with the bar pins removed they won't fit. I'd like to see pics of how you made them work.... Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted May 27, 2008 Share Posted May 27, 2008 You can get MJ shock sets here; http://motionoffroad.com/catalog/index. ... =13_28_106 The skyjackers have a $35 cash back rebate I believe going on until the end of the month. Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 27, 2008 Share Posted May 27, 2008 Here's the cross reference. I have had this list for ages, and do not remember who sent it; I think it was Gojeep (Marcus). When I first got my MJ I used it and picked up a set of new NOS Toyota Land Cruiser shocks on Ebay for cheap, and they worked perfectly, although a bit stiff. All the shocks on this page are supposed to have similar characteristics, i.e. mounting type and travel, for unlifted MJs. Link to comment Share on other sites More sharing options...
SuperWade2 Posted May 27, 2008 Share Posted May 27, 2008 I ordered mine from Amazon.Com actually... Stock Height... Can probably get better prices, but I like the free shipping on Amazon and no Tax. Monroe 37026 (Front) - $47/ea now (were $35 when I got em) http://www.amazon.com/gp/product/B000C53QTA Monroe 37029 (Rear) - $40/ea http://www.amazon.com/gp/product/B000C53QSG Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 27, 2008 Share Posted May 27, 2008 I ordered mine from Amazon.Com actually... Stock Height... Can probably get better prices, but I like the free shipping on Amazon and no Tax. Monroe 37026 (Front) - $47/ea now (were $35 when I got em) http://www.amazon.com/gp/product/B000C53QTA Monroe 37029 (Rear) - $40/ea http://www.amazon.com/gp/product/B000C53QSG Ouch - too high IMHO. I like Amazon too, but their free shipping is usually built into the selling price. I went down my list looking for NOS shocks on Ebay one by one, and found the Toy Land Cruiser rear set for $21 shipped. Didn't want to spend a lot of $ since I knew I would be lifting soon. Two years later I finally did.........then got OME shocks. Link to comment Share on other sites More sharing options...
fatcat0491 Posted May 27, 2008 Author Share Posted May 27, 2008 MEh i might go through rustys offroad 30 bucks each :( Link to comment Share on other sites More sharing options...
BLHTAZ Posted May 27, 2008 Share Posted May 27, 2008 MEh i might go through rustys offroad 30 bucks each :(Just remember that you get what you pay for when you are looking for new ones again in a year or so. ;) I have used nothing but ProComp ES9000 shocks for about 5 years now. They are not expensive at around $40 each, but are far better quality than most in that range. Link to comment Share on other sites More sharing options...
pingpong Posted May 27, 2008 Share Posted May 27, 2008 I swear by Doesch tech (sp) they are kinda cheap and work great Link to comment Share on other sites More sharing options...
Eagle Posted May 30, 2008 Share Posted May 30, 2008 Why can't XJ shocks work in the rear? :huh???: I just put a set of 3" XJ shock front and rear of my comanche. Works just fine. They were a perfect fit for my 3" AALs. XJs have bar pins in the top mounting, just don't put the bar pin in the shock. Stock XJ rear shocks are too short for an MJ. I tried to cheap out and put a set from an XJ into an MJ. With the truck sitting on the axles on jack stands (IOW at stock ride height), the shocks when fulley expended were 1/2" to 3/4" too short to span between the upper and lower mounting studs. Link to comment Share on other sites More sharing options...
