Have a Tach Cluster on the way for a swap into my MJ...
1 "simple" Question....This is the "Dummy Light" cluster that people talk about, correct? And if So, I will need to install some new sensors (which I'm sure I can find the part #'s and such if I searched for em on here - unless someone wanted to link a thread or just give me the #'s)...
#2
OEM Sensor Part Numbers:
Temp: 53005309
Oil: 53005218 superceded by 56026782
Will I have to get these at the Stealership? Nearest is nearly an hour away depending on Traffic...
#2
superwade2. if you click on the link i attached it will tell you the part numbers to a autozone. if there is one near you. you should beable to use those numbers to other parts stores.
Temp: 53005309
Will I have to get these at the Stealership? Nearest is nearly an hour away depending on Traffic...#2
Usually, a parts house can cross the numbers and get the correct aftermarket replacement if that's what you want. My local Autozone got it right for me. :cheers:
Yeah, just saw that... replied before I looked at the other post... No AutoZones either... Well, the same 30-45 minute drive as the stealership...
Will check the local yocals to see if they have equivalent part #'s.
Sw2
Just left the Local Parts Place (a Winchester Auto, which is local, but tied into Parts+Plus) and they wanted almost $30 for the one sensor and nearly $40 for the second... I didn't ask which was which, laughed at the counter jockey and left... Am I crazy, or does that sound insanely pricey (and for not having it in stock)...
SW2
thats way too much. there morons. i paid 9 bucks for one and 18 for the other. no way in hell is those 2 pieces that expensive. is there any other part stores near you?
Same place that wanted like $80 for MOOG BallJoints that I ended up buying on Amazon.Com for like $45 or whatever...
Kragen, which is tied to Parts America... NAPA down in Santa Cruz, which is 15 or so minutes away...
