offroader461 Posted June 4, 2008 Author Share Posted June 4, 2008 ehaust is good....it finally quit completely running b4 i did the distributor change over and it was put back the right way...so i know its not the distributor....and no i had the engine rebuilt about 25-30K b4 and i know it didnt jump the timing chain...see my delima LOL Link to comment Share on other sites More sharing options...
87ComancheLB Posted June 4, 2008 Share Posted June 4, 2008 Sometimes you can tell that a converter is clogged because you don't go any faster when you push the gas pedal. Also, there usually is a noticeable drop in gas mileage associated with a clogged catalytic converter. A partially clogged converter often acts like an engine governor, limiting the actual RPMs to a fast idle. A totally clogged converter causes the engine to quit after a few minutes because of all the increased exhaust back pressure. :brows: Link to comment Share on other sites More sharing options...
offroader461 Posted June 4, 2008 Author Share Posted June 4, 2008 hmmm...ill check that but i think its fine...replaced it last year for emmissions purpose :mad: all suggestions are helpful to narrow it down :cheers: Link to comment Share on other sites More sharing options...
deziped Posted June 4, 2008 Share Posted June 4, 2008 By chance did your MAP line pop out of the side of the TB. Mine did & I experienced the exact symptons you pointed out originally. Plugged it back in & it went back to normal oper. Link to comment Share on other sites More sharing options...
87ComancheLB Posted June 4, 2008 Share Posted June 4, 2008 Are you getting fuel in the combustion chamber? are your plugs moist with fuel when you pull them? Link to comment Share on other sites More sharing options...
Ben-88Comanche Posted June 4, 2008 Share Posted June 4, 2008 if you have fuseable links, check them. One of mine was bad and when you turnedf the key to run it would die, but maybe yours is just a weak connection or something? pull on them to see if they come apart, if it stretches, replace it Link to comment Share on other sites More sharing options...
streetjeep2.5 Posted June 4, 2008 Share Posted June 4, 2008 Do 87's have the crankshaft sensor? My 94 4.0 started falling all over itself and it was the crankshaft sensor. Link to comment Share on other sites More sharing options...
Eagle Posted June 4, 2008 Share Posted June 4, 2008 Do 87's have the crankshaft sensor? My 94 4.0 started falling all over itself and it was the crankshaft sensor. Yes, they do. Link to comment Share on other sites More sharing options...
offroader461 Posted June 4, 2008 Author Share Posted June 4, 2008 -yea the plugs got fuel all over them so i switched them out with a new set -MAP line is good -Crank sensor is brand new Ill check the fuseable links..never thought of that Link to comment Share on other sites More sharing options...
maddzz1 Posted June 5, 2008 Share Posted June 5, 2008 if you have fuseable links, check them. One of mine was bad and when you turnedf the key to run it would die, but maybe yours is just a weak connection or something? pull on them to see if they come apart, if it stretches, replace it I'm gonna go with this too. I had th same problm as bn. Rlease key to run and it would stall. Mine was actually a bad wire next to the fusible link near the battery Link to comment Share on other sites More sharing options...
offroader461 Posted June 8, 2008 Author Share Posted June 8, 2008 ITS ALIVE!!!!! Re-checked the timing and it was slightly off...spend 30min trying to get it right and first flip of the key she fired right up!! I'm so relieved that it runs but now about 1500 RPM it starts to stumble and backfire...and ideas on that?? Link to comment Share on other sites More sharing options...
mvusse Posted June 8, 2008 Share Posted June 8, 2008 Timing is off. Too far advanced. Link to comment Share on other sites More sharing options...
offroader461 Posted June 9, 2008 Author Share Posted June 9, 2008 ALL FIXED!!! :cheers: :cheers: :cheers: :jump: Link to comment Share on other sites More sharing options...
MiNi Beast Posted June 9, 2008 Share Posted June 9, 2008 timing then? Link to comment Share on other sites More sharing options...
offroader461 Posted June 9, 2008 Author Share Posted June 9, 2008 yea i was one tooth off Link to comment Share on other sites More sharing options...
MiNi Beast Posted June 9, 2008 Share Posted June 9, 2008 Image Not Found Link to comment Share on other sites More sharing options...
offroader461 Posted June 9, 2008 Author Share Posted June 9, 2008 Yea but hey I'm finally happy it runs!!! been way too long...now i finally get to pull it in the driveway and put on my RK X-factor steering and roll-bar i got Link to comment Share on other sites More sharing options...
MiNi Beast Posted June 9, 2008 Share Posted June 9, 2008 always good when it runs. Link to comment Share on other sites More sharing options...
