maddzz1 Posted April 19, 2008 Share Posted April 19, 2008 The black molding that runs the length of the truck (the one that protects the paint from other car doors hitting the paint) is peeling off my passenger side door. What can I use to get it to stick back on? Or where can I order a new one? Link to comment Share on other sites More sharing options...
mvusse Posted April 19, 2008 Share Posted April 19, 2008 I'm pretty sure it can just be glued back on, but I don't know off hand what to use. It happened to a friend of mine recently and her neighbor fixed it for her. If I remember I'll ask him what he used. Link to comment Share on other sites More sharing options...
maddzz1 Posted April 19, 2008 Author Share Posted April 19, 2008 I'm pretty sure it can just be glued back on, but I don't know off hand what to use. It happened to a friend of mine recently and her neighbor fixed it for her. If I remember I'll ask him what he used. Thanks, It looks like it happened to my driver side before. And they put it back on then used two screws at the front of it. Link to comment Share on other sites More sharing options...
james750 Posted April 19, 2008 Share Posted April 19, 2008 On my dads xj this happened and we used LORD Adhesives (i believe its a 3m brand), Its normaly used on the ends of studs or strait to letters to hold signage up on a wall. you just mix it, lay it, leave it. oh, and make sure to get all of the glue off your hands within minutes of applying, when the glue sets it lets off lots of heat. Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 19, 2008 Share Posted April 19, 2008 The black molding that runs the length of the truck (the one that protects the paint from other car doors hitting the paint) is peeling off my passenger side door. What can I use to get it to stick back on? Or where can I order a new one? Pull the piece completely off, then scrape off all remaining adhesive on both the rubber trim piece and the body. A heat gun and/or GOO-Gone and a sharp putty knife works well. Then clean up the trim and body with rubbing alcohol, and re-attach using 1/2" 3M double-sided tape. Link to comment Share on other sites More sharing options...
comanche87 Posted April 19, 2008 Share Posted April 19, 2008 i agree with hornbrod. i would do that. Link to comment Share on other sites More sharing options...
maddzz1 Posted April 19, 2008 Author Share Posted April 19, 2008 The black molding that runs the length of the truck (the one that protects the paint from other car doors hitting the paint) is peeling off my passenger side door. What can I use to get it to stick back on? Or where can I order a new one? Pull the piece completely off, then scrape off all remaining adhesive on both the rubber trim piece and the body. A heat gun and/or GOO-Gone and a sharp putty knife works well. Then clean up the trim and body with rubbing alcohol, and re-attach using 1/2" 3M double-sided tape. Thanks, That sounds easier than the other way. Link to comment Share on other sites More sharing options...
comanche87 Posted April 28, 2008 Share Posted April 28, 2008 let me know ill give ya a hand fixing that. i have the double face tape to fix it. the stuff for moldings. Link to comment Share on other sites More sharing options...
Eagle Posted April 28, 2008 Share Posted April 28, 2008 There's a specific type of double-face tape made for the purpose. Any auto parts place should have it with the paint and body supplies. It's cleverly called "molding & emblem tape." Link to comment Share on other sites More sharing options...
gixxerman600 Posted April 28, 2008 Share Posted April 28, 2008 pull um all off i did and it loks good. Link to comment Share on other sites More sharing options...
wooky48 Posted April 28, 2008 Share Posted April 28, 2008 There's a specific type of double-face tape made for the purpose. Any auto parts place should have it with the paint and body supplies. It's cleverly called "molding & emblem tape." That sound like just what I need to rehang the "Comanche" emblem back on the fender, thanks yall. Link to comment Share on other sites More sharing options...
92comanche4x4 Posted April 28, 2008 Share Posted April 28, 2008 GORRILA GLUE i love that stuff works good i used it on my fan shroud and i use it on everything lol Link to comment Share on other sites More sharing options...
