mjeff87 Posted May 5, 2006 Share Posted May 5, 2006 Caught a bit of this on a public access channel last night while flipping thru the channels. It's a new concept in rotary engines that employs diesel engine theory. It's called the Rand Cam, and it has no plugs, and it produces 1 hp per .75 lbs of engine weight (compared to conventional piston engines that are about 1 hp per 5 to 6 lbs of engine weight). The thing only has two moving part assemblies! A 6" by 6" prototype version, weighing only 40 lbs, produced 42 hp It's basically the equivalent of a 24 cylinder diesel, 20:1 compression :eek: Anyways, if it piques anyone's interest, here is the website: http://www.regtech.com/directcharge.html Also click the "Rand Cam Technology" link on the page and go to "prototype engine" to see the actual thing. Enjoy! Jeff Link to comment Share on other sites More sharing options...
Pete M Posted May 5, 2006 Share Posted May 5, 2006 Sweeeeeeeeeeet! Link to comment Share on other sites More sharing options...
87manche Posted May 5, 2006 Share Posted May 5, 2006 that's crazy cool, I just wonder about the materials used to seal the sliding bits to the cam. If it can be made durable enough then it will be revolutionary, but until one of thsoe can go 249K miles like my I6 then it's not gonna make it. Link to comment Share on other sites More sharing options...
pingpong Posted May 5, 2006 Share Posted May 5, 2006 Just look at the Mazda rotary engines, I know they are different then what you posted, but all the same Link to comment Share on other sites More sharing options...
DirtyComanche Posted May 5, 2006 Share Posted May 5, 2006 And if you drive them hard, they last maybe 50K. No thanks. Link to comment Share on other sites More sharing options...
feerocknok Posted May 7, 2006 Share Posted May 7, 2006 A big problem with the Wankel (Mazda's rotary) is the apex seals go out on em. People always think their motor's wasted and it makes a worse name for the engine. As far as performance is concerned, Wankels are phenominal. As far as reliability is concerned, they suck... they suck things that shouldn't be sucked. Also, they make poor low-end torque due to their "3-stroke" design. However, this is not a Wankel... A+ Link to comment Share on other sites More sharing options...
c0mt3k Posted May 14, 2006 Share Posted May 14, 2006 A big problem with the Wankel (Mazda's rotary) is the apex seals go out on em. People always think their motor's wasted and it makes a worse name for the engine. As far as performance is concerned, Wankels are phenominal. As far as reliability is concerned, they suck... they suck things that shouldn't be sucked. Also, they make poor low-end torque due to their "3-stroke" design. However, this is not a Wankel... A+ agreed on the A+. Good find! Link to comment Share on other sites More sharing options...
