muriatic acid...cab corners?
I'm trying to think of things i can pour into my cab corners to remove any stint of rust in there. i don't trust the "spray the rust and it'll convert" crap they're selling.
oh, the paint is coming off down there when i replace the small chunk anyways, so IDC about paint for the bottom 7" of the truck.
anyone think muriatic acid would work?
Jeepco, If you do it maybe you could take some before and after pics.
yea i'll do a writeup.
i'm gonna have to find something trustworthy to use on it...i don't want any more rust on that truck (this is the last winter it will be driven in...and i only drove it for the past 2 tanks of gas in the winter thank god)
I think you could do it then flush it out. But you've got to do a really good job of getting it off. I know when they dip cars/parts then normally pressure wash them like crazy afterwards to make sure they're completely clean.
I'd probably spray it with zinc chromate afterwards.
It'll work like a charm. I used to use it to clean steam boiler elements of hard water chemical build up. The heater cores were copper, around a ten to fifteen minute submersion bath in Muratic acid would eat away most of the build up. Had to follow up on the tuffer spots with a brass brush in the Muratic bath. All it did to the copper was shine it up. Rubber gloves, goggles and a respirator are required. Since Muratic acid is 100% water soluable all you need is a 10 minute flush and your done. Warm water works best but cold will get it done just use more.
