offroader461 Posted March 16, 2008 Share Posted March 16, 2008 Hey all...as you know i just got the suspension on the MJ done and finally got it on the road after 2mnths...well now the radio won't come on...i had to pull the carpet and such out to fix some surface rust on the floors and when i went to reprogram the setting the radio won't turn on...i checked the fuse and its good and looked over all the wiring and its ok...the radio worked GREAT b4 and now it just has nothing...ANY IDEAS/SUGGESTIONS?? Link to comment Share on other sites More sharing options...
aerocorey Posted March 16, 2008 Share Posted March 16, 2008 Check the fuse, check grounds. Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 16, 2008 Share Posted March 16, 2008 Hey all...as you know i just got the suspension on the MJ done and finally got it on the road after 2mnths...well now the radio won't come on...i had to pull the carpet and such out to fix some surface rust on the floors and when i went to reprogram the setting the radio won't turn on...i checked the fuse and its good and looked over all the wiring and its ok...the radio worked GREAT b4 and now it just has nothing...ANY IDEAS/SUGGESTIONS?? Have you pulled the radio and checked for power and ground on the connector? Should be like this: Pin 4 (Pink): 12V constant Pin 5 (Vio/Wht): Ignition Switched 12V Ground attached to a lug on the chassis Link to comment Share on other sites More sharing options...
Mattpioneer Posted March 16, 2008 Share Posted March 16, 2008 is it the stock radio? because i had the same problem just got new radio Link to comment Share on other sites More sharing options...
offroader461 Posted March 16, 2008 Author Share Posted March 16, 2008 checked fuse and ground...both good no its a aftermarket PIONEER CD player like i said it was perfect b4 all this and for some reason it just won't turn on...i can't for the life of me figure out why?? Link to comment Share on other sites More sharing options...
akamcbird Posted March 16, 2008 Share Posted March 16, 2008 proly got a blown speaker or grounding speaker wire, un plug the head unit entirly then plug it back in, should come on breifly you can check the speaker wires individualy for continuity against the body (should not have continuity) i found that one of the terminals on a 6x9 was broke and grounding to the speaker frame yaya the splling sux cuz i just rolled outa bed and dontb care Link to comment Share on other sites More sharing options...
ifixit8 Posted March 18, 2008 Share Posted March 18, 2008 checked fuse and ground...both good no its a aftermarket PIONEER CD player like i said it was perfect b4 all this and for some reason it just won't turn on...i can't for the life of me figure out why?? if you take a volt meter to the constant and the switched wires to ground, you should have voltage on both. if everything is good, then I'd say blown radio. if speakers we're blown the radio would still power up, just not produce sound. same thing goes for speaker wires that are grounding out. Link to comment Share on other sites More sharing options...
luke87 Posted March 19, 2008 Share Posted March 19, 2008 could be the ignition switch. check on top of ur steering column. there should be a blue plug/connector. i had the same problem, and it turned out the plug was melted. Link to comment Share on other sites More sharing options...
smithe1811 Posted March 19, 2008 Share Posted March 19, 2008 geez, when i fried my ignition switch my truck would just shut off at random, of course this happend hours from home and i was forced to leap frog all the way back. Link to comment Share on other sites More sharing options...
offroader461 Posted March 19, 2008 Author Share Posted March 19, 2008 ignition switch was already replaced when i tightened up the tilt mechanism bolts along with the tumbler....i have the radio out of the truck and am going to check for voltage and the grounds tomorrow Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 20, 2008 Share Posted March 20, 2008 It's not the ignition switch, speakers, etc. Turn on the key w. the radio removed and check the following pins on the radio harness plug (if it's still there): Pin 4 (Pink): 12V constant Pin 5 (Vio/Wht): Ignition Switched 12V Ground attached to a lug on the chassis Link to comment Share on other sites More sharing options...
offroader461 Posted March 20, 2008 Author Share Posted March 20, 2008 It's not the ignition switch, speakers, etc. Turn on the key w. the radio removed and check the following pins on the radio harness plug (if it's still there): Pin 4 (Pink): 12V constant Pin 5 (Vio/Wht): Ignition Switched 12V Ground attached to a lug on the chassis Ill definantly check that tomorrow..THX Much Link to comment Share on other sites More sharing options...
