MWinland Posted February 14, 2008 Share Posted February 14, 2008 I want to upgrade to larger u-joints in my D30 w/ cad, but I want to keep the cad (posi). Can I use the driver side off a 96+ XJ on the passanger side for the outer? Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted February 15, 2008 Share Posted February 15, 2008 You will need a set of shafts from a 1995 Jeep YJ. CW Link to comment Share on other sites More sharing options...
Pete M Posted February 15, 2008 Share Posted February 15, 2008 Some quick and dirty research a while back pointed to ABS equipped 93-95 YJs having the right shafts for the bigger joints. Don't know for sure what is accurate though. :( Link to comment Share on other sites More sharing options...
Rokhound Posted February 15, 2008 Share Posted February 15, 2008 Mad XJ http://www.madxj.com/MADXJ/technical/te ... dSeals.htm Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted February 15, 2008 Share Posted February 15, 2008 Some quick and dirty research a while back pointed to ABS equipped 93-95 YJs having the right shafts for the bigger joints. Don't know for sure what is accurate though. :( Yes they will..but they will not be disco axles. Those went away with the HO in 1991. CW Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted February 15, 2008 Share Posted February 15, 2008 Mad XJ http://www.madxj.com/MADXJ/technical/te ... dSeals.htm This is a good option is you want to eliminate the diso. CW Link to comment Share on other sites More sharing options...
Oizarod115 Posted February 16, 2008 Share Posted February 16, 2008 Mad XJ http://www.madxj.com/MADXJ/technical/te ... dSeals.htm This is a good option is you want to eliminate the diso. CW look though, he didn't eliminate the disconnect... he used a 95 YJ passenger side shaft and kept the disconnect and the 297 joint Link to comment Share on other sites More sharing options...
jeepthing07 Posted February 17, 2008 Share Posted February 17, 2008 Some quick and dirty research a while back pointed to ABS equipped 93-95 YJs having the right shafts for the bigger joints. Don't know for sure what is accurate though. :( Yes they will..but they will not be disco axles. Those went away with the HO in 1991. CW All YJ's had the disco axle. I think it was in 1994 they went to the 297X joints on the ABS equiped YJ's but in 1995 all of them got the bigger joints. I don't really know if the 297X joints are a upgrade when useing the stock shaft because the holes were just bored out bigger to accept the bigger caps. my friend ripped the ears off the inner shafts on both sides on his TJ the joints dident even break. The ears on my YJ's shafts were bent in slightly and couldent get the clips on the caps so i bought some non disco 297X shafts off ebay Link to comment Share on other sites More sharing options...
