bhorocks Posted January 25, 2008 Share Posted January 25, 2008 how did people go about getting that rigged up? I am thinking about using wahsers and shimming but would like to just make it work with the vacuum for now... what did you do to make it work? Link to comment Share on other sites More sharing options...
oldjeep Posted January 25, 2008 Share Posted January 25, 2008 If you had to swap in a front axle, why in the world did you swap in a disconnect front? Link to comment Share on other sites More sharing options...
DrThunder Posted January 25, 2008 Share Posted January 25, 2008 i like my disconnect, i spent 20 bucks on a heavy duty throttle cable that locks when you turn it to the right and welded up my front end. cheap and very effective locker :brows: nobody down it either, it works for me and i like it Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted January 25, 2008 Share Posted January 25, 2008 POSI-LOC baby!!! Its WAY better then the problematic vacuum system!! http://www.4x4posi-lok.ca/ http://www.thejeep.com/onlinecatalog/p72.htm CW Link to comment Share on other sites More sharing options...
Rokhound Posted January 25, 2008 Share Posted January 25, 2008 go to O Reilly’s and get a band clamp the really wide one for 1.00 and call it good. All it has to do is hold it over. Cheap and easy. Link to comment Share on other sites More sharing options...
mjeff87 Posted January 25, 2008 Share Posted January 25, 2008 washer method I've been using on my MJ below, takes about 10 minutes and 6 or 7 washers. I'm eventually going back to the vac motor, but using a manual vac switch in the cab, when/if I add a front locker. Jeff Image Not Found Link to comment Share on other sites More sharing options...
bhorocks Posted January 26, 2008 Author Share Posted January 26, 2008 well. used the washer for now. also got a posi-lok for 50 dollars. waiting for it currently! first chance to mildly flex it hopefully get it out on a trail this weekend. the hotel i wokr at is hosting the Giants and has kept me busy so we will have to see about going out! Link to comment Share on other sites More sharing options...
bhorocks Posted January 26, 2008 Author Share Posted January 26, 2008 If you had to swap in a front axle, why in the world did you swap in a disconnect front? because it had 4.10s cheaper to get one peice shafts at the JY than to get an axle with the wrong gear ratio then swap over. Link to comment Share on other sites More sharing options...
JOMJ87 Posted January 26, 2008 Share Posted January 26, 2008 How did you get a posi lock for 50 bucks that makes me want to buy one if i got it that cheap. I have a homebrew to instal but i don't like the design. Cole Link to comment Share on other sites More sharing options...
bhorocks Posted January 26, 2008 Author Share Posted January 26, 2008 used Link to comment Share on other sites More sharing options...
