fiatslug87 Posted Thursday at 04:35 AM Posted Thursday at 04:35 AM POR-15 is a urethane coating that is Painted Over Rust. There’s a cleaner that should be used before application.
jodawill Posted Thursday at 04:02 PM Author Posted Thursday at 04:02 PM 11 hours ago, fiatslug87 said: POR-15 is a urethane coating that is Painted Over Rust. There’s a cleaner that should be used before application. Thanks. I just ordered the degreaser, metal prep, and clear coating. Apparently this stuff is hard to find locally. What do I need to know before I use this stuff? Do I need to pull out all of the old sealer and apply some fresh sealer? I'm spending a lot of money on sound dampening materials, so I don't want to make any mistakes here.
Pete M Posted Thursday at 10:28 PM Posted Thursday at 10:28 PM I would leave the seam sealer alone if there isn't any sign of rust. if there's any hint of rust at the edge of some sealer, I would use a wire brush on a drill or grinder to explore how far it goes. keep in mind that preventing water intrusion is the single most important step to preventing rot. the floors are complicated and you cannot rustproof every nook and crevice. heck, if it stays dry, you can leave it completely alone and it'll be just fine forever
