I have recently developed a burning smell in the cab, and I am curious to see what theories evolve here.
- Smell develops after ~15 minutes of driving.
- No visible smoke.
- Smells very akin to burning brakes.
- I usually am not running the blower motor. It has been very moderate temps here.
- I usually am not driving at night.
- Could be clutch starting to go but I am not ragging on it and am not lugging the engine. Tach follows vehicle speed when in gear.
All of the wheels are cool to the touch. When I pop the hood, no smoke comes from underneath. When I leave it running in the driveway I do not appear to have any major leaks (like rear main on the exhaust pipe...).
I don't have a ton of time to dig into it right now, so it is mostly sitting parked. I might get a few hours this weekend to look at it but figured I would ask for common things. This thing has so many things wired into the cab that I would not be surprised if it is electrical, but it smells different than the overheating speakers from the likely overpowered amplifier (another thing I have not fixed =P).
Burning electrical and hot brake/clutch material do smell about the same.  Look at the wiring under the dash for sure.  Also check to see if anything that shouldn't be is running against the exhaust.
Don't know you're truck but only time I've smelled burning plastic in an MJ and XJ was the HVAC control connector to fan speed selection. Both Jeeps were over 200K at the time.
This is what I assumed originally but I have been driving it without blower for a while now. Only way to know for sure is for me to pull that out.
I noticed my door speaker doesn't seem to be outputting anymore... I wonder...
Power still runs to that connector even with out the blower motor installed. The dividers of the connector melt essentially connecting (typically) 3 of the 5 wires.
On 6/12/2026 at 5:49 AM, Pete M said:
do you have an non-contact thermometer?
do you have a fire extinguisher?
I have a pyrometer, it's industrial and connects to a laptop for data acquisition so not the most convenient for this application =P
I did not have a fire extinguisher but I just ordered one!
I would try and isolate potential causes such as:
leave the truck off and the radio blasting for a while.
fire up the truck, let it idle for a while and leave everything else off.
drive around without non-essential electrical things on.
BTW I did figure this out...
My Driver's door speaker is definitely no longer working, any sign of burning smell has also left.
4 hours ago, Pete M said:
you should open that up asap and make sure the wire isn't grounding out.
I am actively building a rear cab replacement harness and new door harnesses. This experience is telling me it is time to get off my butt and actually fix the electrical from the cab back. I am nearly done with the rear cab harness and just need to make the fuel pump and rear extension harness that matches and I will put it all in at once in a few weeks.
All 20ga bumped to 18ga GXL, 16ga power for Fuel pump bumped to 14ga GXL. Deutsch terminated on most connectors. All sleeved with mostly solid expandable sleeving.
The wiring on this truck has been a bit of a known issue from years of random accessories tapped in. From the kick panel back has always been the most problematic so I guess I just got annoyed enough to fix it =P
