87_Pioneers Posted May 5 Posted May 5 1989 was grey at one point with a 4.0 AX15 combo and grey full console and buckets. Remainder of the truck is headed for scrap by the end of the month.
AnotherOldJeepGuy Posted May 5 Posted May 5 Well if you were a lot closer to Texas, and assuming the 89 fenders were interchangeable with 90, and my 90 wasn't dead right now, I'd be trying to get that right front fender from you! At least from what I can see it is a lot straighter than mine
89 MJ Posted May 5 Posted May 5 19 minutes ago, AnotherOldJeepGuy said: Well if you were a lot closer to Texas, and assuming the 89 fenders were interchangeable with 90, and my 90 wasn't dead right now, I'd be trying to get that right front fender from you! At least from what I can see it is a lot straighter than mine The part that mounts the fender flare has been cut off. There looks to be a lot of other usable parts on that truck still though!
jdog Posted Monday at 02:09 AM Posted Monday at 02:09 AM BODY: JM61 BUILD: 05/10/89 SELLING DEALER: HALL JEEP CHRYSLER VIRGINIA BEACH, VA *X1 DESCRIPTION NOT AVAILABLE -SA CHARCOAL ADLA SKID PLATE GROUP ALN DECOR PACKAGE CBAP STRAIGHT BACK BENCH SEAT DBBC ALL MANUAL TRANSMISSIONS DDQ 5-SPEED MANUAL TRANSMISSION EAAC ALL ENGINES EAFC ALL ENGINE ERB 4.0L I6 MPI ENGINE GEC FRONT LEFT SIDE SLIDING WINDOW GFDA REAR SLIDING WINDOW GRZP LEFT REMOTE MIRROR GSZP RIGHT REMOTE CONTROL MIRROR GTZA MANUAL REMOTE MIRRORS JAYA DO NOT USE - SEE JP, KA CLASSES JGBP JHAA VAR INTERMITTENT WINDSHIELD WIPERS MDAP FRONT LICENSE PLATE BRACKET PS3 Dover Gray RAAC ALL RADIO EQUIPPED VEHICLES RABA OPEN RCDP 4 SPEAKERS TAAC ALL TIRES TAEA TBBA FULL SIZE SPARE TIRE TMWA TIRES WJM 15X7.0 CHROME WHEELS XEEP FUEL TANK SKID PLATE SHIELD XEFP TRANSFER CASE SKID PLATE SHIELD XEUP FRONT SUSPENSION SKID PLATE YEP MANUF STATEMENT OF ORIGIN YGEA 5 ADDITIONAL GALLONS OF GAS Z01P REAR SPRING GROUP I Z65P LEFT FRONT GROUP XIV Z84P RIGHT FRONT SPRING GROUP XIII 5AMA JF/3450 VEHICLE FAMILY 5KNA APAS MONOTONE PAINT BAQS 115 AMP ALTERNATOR BCXS Dual 700 Amp Maint. Free Batteries BGAS POWER FRONT DISC/REAR DRUM BRAKES BJAS DESCRIPTION NOT AVAILABLE BKPS 10X2.5 REAR DRUM BRAKES CKAS CARPETS - FLOOR AND CARGO AREA CSRS DO NOT USE - SEE CLASS JV CUMS MINI FLOOR CONSOLE DHNS COMMAND-TRAC PART TIME 4WD SYSTEM DJHS FRONT AXLE DMMS 3.07 REAR AXLE RATIO DRJS DANA M235 WIDE REAR AXLE GACS TINTED GLASS WINDOWS GBBS TINTED WINDSHIELD GLASS GCBS FRONT DOOR TINTED GLASS GNAS REAR VIEW DAY/NIGHT MIRROR HCDS DO NOT USE - SEE HCA JAAS INSTRUMENT PANEL JBDS INSTRUMENT PANEL SATIN SILVER BEZEL JCAS SPEED GRADUATION-MILES JJAS CIGAR LIGHTER JKBS DMO11 - CARGO OPENING VIA REMOTE KEY KKES DESCRIPTION NOT AVAILABLE K2XS STRIPE/BADGE/MOLDING/COLOR K3DS STRIPE/BADGE/MOLDING/COLOR LAFS SEAT BELT ALERT-DRIVER SEAT ONLY LAPS SHIFT INDICATOR WARNING LAMP LBCS GLOVE BOX LAMP LCJS OVERHEAD AMBIENT SURROUND LIGHTING LMAS HALOGEN HEADLAMPS MBJS BLACK POWDER COATED FRONT BUMPER MB1S BLACK FRONT BUMPER MFGS HEADLAMP BEZEL MHAS BLACK WINDSHIELD MOLDINGS MMCS REAR SWING DOOR PANEL INSERTS MMGS BELT MOLDINGS MMKS LOWER GRILLE SURROUND-PAINTED SILVER NAAS FEDERAL EMISSIONS NBAS UNDERGROUND CALIBRATION NBKS SELECTIVE CATALYTIC REDUCTION - WITH NDAS CATALYTIC CONVERTER NF2S 18 GALLON FUEL TANK QS3S Dover Gray SBAS POWER STEERING SCES ALCANTARA WRAPPED STEERING WHEEL SFAS STANDARD DUTY FRONT SHOCK ABSORBERS SGAS STANDARD DUTY REAR SHOCK ABSORBERS TBMS TIRE CARRIER WINCH XBSS PICKUP BOX XFAS -35F PROTECTION ANTI-FREEZE YAAS BUILD TO U.S. MKT. SPECIFICATIONS Z5AS GVW/PAYLOAD RATING 1AAS U.S. DEALER RETAIL 135S ZONE 35-WASHINGTON
