Darren Posted January 18, 2008 Share Posted January 18, 2008 1. What do I do about the Reverse light wiring? Plugs don't match at all. 2. Removed my stock 21 spline case and went with a case from a 93. What do I do about my speedo cable, new case has an electrical plug. And how much of the vacuum line crap can I remove since i no longer have a disconnect axle? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted January 18, 2008 Share Posted January 18, 2008 1. What do I do about the Reverse light wiring? Plugs don't match at all. 2. Removed my stock 21 spline case and went with a case from a 93. What do I do about my speedo cable, new case has an electrical plug. And how much of the vacuum line crap can I remove since i no longer have a disconnect axle? 1. splice the wiring together, or go to a parts store to get the correct pigtail (or matching set of pigtails to splice in) 2. your stock 21 spline wouldn't fit on an ax15, since they are 23 spline I believe. so, if your ax15 had a 21 spline that wouldn't make sense. 3. remove all of the vaccuum stuff, then just get some plugs for the sender on the t-case. that vacuum hosing ONLY pertains to the t-case and doesn't interconnect with the engine vacuum, so you won't suffer vacuum leaks. remember, the t-case vacuum stuff consists of colored hard hoses with rubber ends, and the metal hardline piece between them. so, only pull those ones Link to comment Share on other sites More sharing options...
Darren Posted January 18, 2008 Author Share Posted January 18, 2008 my stock ba-10 case was a 21 spline the ax-15/231 combo was out of a 93 it is a 23 spline Link to comment Share on other sites More sharing options...
MiNi Beast Posted January 18, 2008 Share Posted January 18, 2008 add some leds out back and toggle it inside, nice for out on trails and for those a ss huggers on the road, just be sure not a cop. :rotfl2: Link to comment Share on other sites More sharing options...
Pete M Posted January 18, 2008 Share Posted January 18, 2008 I think you should be able to use your old speedo gear and housing inside the new t-case. Link to comment Share on other sites More sharing options...
