Question about gear ratios and carrier breaks
A Dana 35 break is between 3.31 and 3.55 so you would need a new carrier for it.  Either that or thick cut 3.55 gears if they make those.
The dana 44 break is between 3.73 and 3.92 so you're good there.
The AMC 20 has a break between 2.73 and 3.08 so you would be good there.
That's the 3 axles that came from the factory.
