1986goose Posted yesterday at 01:53 AM Share Posted yesterday at 01:53 AM How’s my pattern boys? I’m putting Yukon gears into a Chrysler 8.25 I pulled from the junkyard so I can put that into my 86 MJ. Right now I’m running an open diff 4.10 D35. Any recommendation on how many shims I need to set pinion depth? I’m guessing at least 0.004” lol. It’s really bad maybe I should jump to 0.006” I only want to put it back together once. Thanks, Link to comment Share on other sites More sharing options...
derf Posted yesterday at 02:21 AM Share Posted yesterday at 02:21 AM That's way off. And you don't show the other side of the teeth so we can't see the other half of the pattern. And I know you don't want to take it apart multiple times but you will very likely have to. It's part of the process. Link to comment Share on other sites More sharing options...
89 MJ Posted yesterday at 02:29 AM Share Posted yesterday at 02:29 AM Link to comment Share on other sites More sharing options...
1986goose Posted yesterday at 02:41 AM Author Share Posted yesterday at 02:41 AM 12 minutes ago, 89 MJ said: Ok but if you had to guess Link to comment Share on other sites More sharing options...
derf Posted yesterday at 02:49 AM Share Posted yesterday at 02:49 AM Need to see the other side of the teeth to know what to recommend. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted 22 hours ago Share Posted 22 hours ago I’m a little confused here. The 8.25 doesn’t use any shims. It has side adjusters and a crush sleeve. Link to comment Share on other sites More sharing options...
1986goose Posted 22 hours ago Author Share Posted 22 hours ago 3 minutes ago, ghetdjc320 said: I’m a little confused here. The 8.25 doesn’t use any shims. It has side adjusters and a crush sleeve. You can put shims beneath the race for the pinion inside (larger) bearing. I did some research and I need to use a caliper to find the difference in depth from the old pinion to new pinion. I’ll start there Link to comment Share on other sites More sharing options...
ghetdjc320 Posted 22 hours ago Share Posted 22 hours ago I’d completely ignore any old settings. Yukon presents its own machining variables anyways. From the looks of your pattern, you’re missing backlash Link to comment Share on other sites More sharing options...
1986goose Posted 14 hours ago Author Share Posted 14 hours ago For reference, I have added 0.004” (four-one thousandths) to the pinion depth. I’m going to remove 0.0005” (I have 0.0015” shims) to bring it to the middle of the tooth. Link to comment Share on other sites More sharing options...
derf Posted 12 hours ago Share Posted 12 hours ago What is your backlash? Link to comment Share on other sites More sharing options...
