My 1989 build
Hello, here’s my build. As purchased, 1989 Comanche Sport Truck, stock, unmolested, originally purchased from a car flipper, it was intended  to be used as a daily driver…4 years later and still in restoration/modification. First picture is the seller picture, second picture as purchased.
Edited by Elwiscon
First mod… have mechanic install a 2.5” lift on it, among other repairs, truck sat on mechanics lot for a couple months (he was too busy to work on it). Picked it up and started working on it, first project: remove bed, clean undercarriage and raptorline it, and, while the tank was dropped, replace fuel pump, only pump i found was an amazon “a-prime” pump that worked but fuel level didn’t…later replaced with a proper MTS unit.
More raptorliner, new exhaust, CAT, headers…
IMG_0198.jpeg.fcfedce1208dbfee488369048170b5c9.jpegIMG_0199.jpeg.f73ce7819d3ebb250aea958abe29f298.jpegIMG_7388.jpeg.72fbbea7c14f1becf7001e0c05754d49.jpeg
Removed vinyl floor…found extensive rust on passenger side, didn’t see it from underneath when truck was purchased
IMG_7389.jpeg.539725192758b41828ce4b27bb92233d.jpegFullSizeRender.jpeg.881881eb754d1c0da345e8d444d9c14e.jpegFullSizeRender.jpeg.bf1aa74ddbf6dcf9896c9651cd2b8e97.jpegIMG_7844.jpeg.8e0c0c953c1c73f72e6d72007d6c2e18.jpegIMG_7986.jpeg.22bc9d3bcd94a084c15d646de60180c4.jpegIMG_7992.jpeg.8e33155df3c3b393b84374fd845a4fa3.jpegIMG_8068.jpeg.d7468ace16aa08eb1ec4c5812abe5703.jpeg
Replaced floor pan (Keystone Parts), covered with POR15
Replaced the following (that i can remember)
-water pump
-thermostat
-Hoses
-radiator
-alternator
-timing chain
-balancer
-fan clutch
-added electric fan, relays, controls
-battery
-sensors
-injectors
-battery cables
-added headlight relays
-valve cover gasket
-head gasket
-rotor/cap
-spark plug-spark plug wires
-egr valve
-vacuum lines
-motor mounts
-Truck had no factory AC, added lines, harnesses, compressor etc (still need to be charged)73813C18-2388-451C-8E07-1B6F0668B5F4.jpeg.85cfdf0bae0b3eac374f6ae00dfe568b.jpegIMG_0197.jpeg.e5a10ab7a96ed762214ae88a26dd3915.jpegIMG_9858.jpeg.ec149d051c19c586d39305c9e985f66a.jpeg
-etc…
