derf Posted November 15 Author Posted November 15 Brackets on. I still have to weld in the spring bases and part of the shock mount. But it's mostly together.
derf Posted November 15 Author Posted November 15 6 minutes ago, Smokeyyank said: Nice! How was it piecing it all together? Not terrible. Getting some 90 degree magnets helps assemble the main truss. Then several C clamps while welding it in. I did forget that the lower control arm brackets have no key to place them. And the instructions don't say. So I'm going to have to do some measuring of both angles and distances before I burn them in.
derf Posted 17 hours ago Author Posted 17 hours ago Don't you hate when your tool breaks in the middle of a job... Dial indicator mount gave up. So I can't finish installing the gears. No way to measure backlash until the replacement arrives on Wednesday. But here it is with the 4.56 gears and ARB locker in progress. Replacement tools will let me finish this next weekend. Then on to the Ford 9 inch rear.
