tail lights and brake lights inop
so i have a previous thread where i got my brake lights fixed because of a wire to the brake light switch and turn signals not working because of a bad flasher. well radio and blower motor weren't working either so after i replaced those fuses they now work great! but my fuse for "park lamp" socket has melted into the block and i no longer have taillights or brake lights, but the turn signals in the rear still work. ive taken off both lights and they look funky so I'm going to try and upload photos for advice to see if this weird wiring job could be the culprit of my melted fuse or not. i have work around for the fuse but there's  no point in doing that yet until i figure out why it melted in the first place. the sockets look real burnt and nasty but i saw a video of a guy with the same thing and no issues. but these ground wires the way they are spliced makes me concerned
Pete: You can see the boot for the clutch master in one of the pics.
Most likely case that Pete is aluding to is that the clutch master cylinder is or has leaked fluid onto the fuse block and "melted" the plastic. Common issue with our trucks. Best fix is a new master cylinder and a fresh fuse block, typically sourced from a xj with auto (No master to leak) trans.
not really, no. :laugh:  it honestly does anything a big phone does, but I much prefer my laptop/mouse (and the 32" tv that's my second screen) over any phone for using the internet, so the annoyances of the tiny phone are limited mostly to correcting voice-to-text on a teeny keyboard with my giant fingers. :dry:
in theory, yes.  but the fuse block should be a high priority at this point.  it's only going to get worse. :(
be sure to get a block from an automatic XJ so you can be sure it hasn't happened to that replacement block already. :L:
Quote
ive got a donor truck thats a 4.0 but an automatic 2wd but ill have to look to see if its the same or not. i did rob the t/s flasher out of it but i had some corrosion and was bad.
