Power stuttering contiuned...
Muncher
Brand new dizzy, iac, tps, map sensor/cruiser map sensor mod and c101c delete andddd its still stuttering. It does seem the new map sensor made it worse so I'm gonna throw the old one back in tommrow. No clue what could be really causing this anyone have any ideas? and what i mean by stuttering is it will be driving along and suddenly loose alot of power kinda feel like miss firing then suddenly gain it back still drives fine and does not brake down or anything but I hate driving it like that. Could the cps cause this? Its basically the only sensors I haven't changed
33 minutes ago, ghetdjc320 said:
Sounds like CPS though I’d throw fuel pump/filter in the mix. Might be worth checking your major ground connection as well if you haven’t already, but specially the engine block and the fuel pump ground behind the left tail light.
Going to check fuel pump ground tommroe all though i think I fixed it when I put new taillights in. The drivers fender ground and engine block ground were done today.
I was having an issue like this in 2022. It would stumble over itself sometimes during acceleration but would never fully stall. YMMV but for me it ended up being a mix of the fuel pressure regulator, vacuum leaks, and possibly the CPS. But mostly the FPR
What did you replace the fuel pressure regulator with? Its part of the rail kinds isn't it
32 minutes ago, Muncher said:
What causes cross fire?
When the tip of the rotor and the tower terminal (cap) are not lined up properly (indexing), sometimes caused by dropping in the Distributor one tooth off. At higher RPM’s when vehicle is calling for MAX advance (timing), rotor will crossfire to the wrong tower terminal. Carbon build up in the Distributor Cap can also cause crossfire.
Ah ok it did thus before changing the distributor as well but I cut the old cap so I could see the rotor it was definitely at number one when I locked it downm
