The Dakota line is for the rear. YJ lines are longer than stock MJ fronts, but I'm not sure if they are quite long enough.
at 6", the YJ lines are not long enough....I put them on mine.
But, I've already bought them ($23 each from NAPA), and they're brand new lines, so I'm gonna keep them and either extend them with some hard lines, or relocate the frame brackets down a couple inches. I'd say they would be good for up to 4-4.5".
Jeff
edit: the Dakota rear line suffices for the rear, but could stand to be longer as well (again, would work fine for up to maybe 4.5"). I'm gonna drop the hardline in the rear also for more, and also unbolt the e-brake cables from the little clips that hold them to the underside of the bed. The stock ones are barely long enough....
I was at 6.5 up front... now close to 5.5. But with DB's need the extra legnth. I have 4" extended YJ lines and they are PLENTY long!!
CW
going to be running long arm set up so gonna need the length. So I guess I'll just get what 22" or 24" lines? That should be good for 6.5'' LA setup.
I bent the metal part of them some, but not nearly as straight as you did CW......I'll try bending them a bit more :D
Jeff
