hgeranium Posted September 11, 2025 Share Posted September 11, 2025 An occurrence that has been happening for almost as long as I've had this MJ, about 3 years now, (88 4.0 AW4) is that, on occasion, during cold starts (sometimes when warmed up too, but more seldom) the motor will rev up hard to ~2000-2200 for a few seconds and come back down. I also had another issue paired with that where the revs would go up and get stuck there, even while driving. This happened seldomly through the last 3 years but really ramped up last month. The throttle would get stuck open. Super jumpy, hard to brake, etc. like the throttle plate was cracked open. I cleaned the TB (no major carbon deposits), ran a can of sea foam, and replaced the IACV a few weeks ago and I haven't seen this problem come back thus far. However, even with the throttle body cleaning and IACV replacement, that high revving phenomena still regularly occurs. I guess I would like to know if this a common occurrence for anyone else and I should just ignore it as an old vehicle quirk. It is my daily driver, so that's why it's more of a concern to me than if it were just a project. TPS is brand new, voltage tested perfect and within that specified resistance range (Cruiser tip #8). Vacuum lines are solid all around, no leaks there. Resetting the IACV does nothing to change it. The truck runs flawlessly other than that. In park it idles steady at around 900rpm and in drive stays steady at ~700. The fact that the truck runs so well otherwise leads me to believe that it's just an old vehicle quirk but wanted to run it by y'all with much more 4.0 experience than I. Thank you! Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted September 11, 2025 Share Posted September 11, 2025 It is probably your manifold bolts. They like to come loose and sometimes fall out. If you remove the air box you can get to all of them from the top of the engine. There are 11 bolts/studs total. Link to comment Share on other sites More sharing options...
hgeranium Posted September 11, 2025 Author Share Posted September 11, 2025 6 hours ago, Eagle_SX4 said: It is probably your manifold bolts. They like to come loose and sometimes fall out. If you remove the air box you can get to all of them from the top of the engine. There are 11 bolts/studs total. Thank you very much! I’ve read about that happening to people but stupidly never checked myself. Link to comment Share on other sites More sharing options...
pizzaman09 Posted September 12, 2025 Share Posted September 12, 2025 Do check that all manifold studs are actually present, particularly the lower one nearest the back. Mine had backed out completely and was missing, I didn't realize it at first. Link to comment Share on other sites More sharing options...
AnotherOldJeepGuy Posted September 24, 2025 Share Posted September 24, 2025 I dug up a pic and then annotated it to help me find all the bolts when I was running down the info to check mine. Link to comment Share on other sites More sharing options...
hgeranium Posted September 24, 2025 Author Share Posted September 24, 2025 1 hour ago, AnotherOldJeepGuy said: I dug up a pic and then annotated it to help me find all the bolts when I was running down the info to check mine. Thanks for the graphic! When tightening my bolts I just used a picture of a manifold gasket and referenced the holes on the bottom I needed to find with the top holes lol Link to comment Share on other sites More sharing options...
AnotherOldJeepGuy Posted September 25, 2025 Share Posted September 25, 2025 Yeah if you don't check them all, might as well not check any! I used the water test. Started up and sprayed a little water in the areas where the manifold contacts the engine. Before I hunted down the bolts and tightened them, when I sprayed the water the idle dropped, identifying there were gaps. After tightening what I found loose, the water had no effect. Nice to get some positive feedback that something actually got better! Link to comment Share on other sites More sharing options...
