1J7FT26E2KL464521
GonzoTheGreat
I almost didn't see it, while driving by, but on the side of CA-13, just outside of Rio Nance, Honduras, I found this... How do I say it... "Heavily modified" MJ.
I didn't get a pic, but there are large rocks stacked behind the seat to counterbalance the crane, in lieu of engine block weight...
The scooter transmission has a driveshaft welded from its output to the MJ tranny input. So I'm sure it was self-propelled like this at one point.
It looks like it's become a permanent fixture here for pulling engines with the electric hoist on the end of the boom.
IMG_20250730_132503536.jpg.93dd7db2d86c913e747219472ab74f23.jpgIMG_20250730_132308045.jpg.f56c4de9feb57b0f3557bfb783348df8.jpg
BODY: TL61
BUILD: 10/31/88
SELLING DEALER: EARTH JEEP EAGLE
KISSIMMEE, FL
*X2 DESCRIPTION NOT AVAILABLE -H9 DESCRIPTION NOT AVAILABLE BCYP 95 AMP BATTERY
CBAP STRAIGHT BACK BENCH SEAT DBBC ALL MANUAL TRANSMISSIONS DDQ 5-SPEED MANUAL TRANSMISSION
EAAC ALL ENGINES EAFC 2.5L I4 MPI ENGINE EPD DESCRIPTION NOT AVAILABLE
GEC FRONT LEFT SIDE SLIDING WINDOW GRVP LEFT MANUAL MIRROR HAA AIR CONDITIONING
NMCP HEAVY DUTY ENGINE COOLING PE8
Dark Vivid Red Metallic
RAAC ALL RADIO EQUIPPED VEHICLES
RAB OPEN RCDP 4 SPEAKERS SBA POWER STEERING
TAAC ALL TIRES TNCA P195/65R15 BSW AS TOURING TIRES YGBA 1 ADDITIONAL GALLONS OF GAS
YGGA 9 ADDITIONAL GALLONS OF GAS Z01P REAR SPRING GROUP I Z57P LEFT FRONT SPRING GROUP VII
Z76P RIGHT FRONT SPRING GROUP VI 5ALA DT-VEHICLE FAMILY
APAS MONOTONE PAINT BAQS 115 AMP ALTERNATOR BGAS POWER FRONT DISC/REAR DRUM BRAKES
BJAS DESCRIPTION NOT AVAILABLE BKPS 10X2.5 REAR DRUM BRAKES CKJS BLACK VINYL FLOOR COVERING
CSRS DO NOT USE - SEE CLASS JV CUMS MINI FLOOR CONSOLE DMFS 4.10 REAR AXLE RATIO
DRJS DANA 35 REAR AXLE GACS TINTED GLASS WINDOWS GBBS TINTED WINDSHIELD GLASS
GCBS FRONT DOOR TINTED GLASS GNAS REAR VIEW DAY/NIGHT MIRROR GUAS OPEN
JAAS INSTRUMENT PANEL JAZS DO NOT USE - SEE JP, KA CLASSES JBFS INSTRUMENT PANEL BLACK BEZEL
JCAS 85 MPH PRIMARY SPEEDOMETER JKBS DMO11 - CARGO OPENING VIA REMOTE KEY KDCS DESCRIPTION NOT AVAILABLE
K3ZS STRIPE/BADGE/MOLDING/COLOR LAFS SEAT BELT ALERT-DRIVER SEAT ONLY LAPS SHIFT INDICATOR WARNING LAMP
LBCS GLOVE BOX LAMP LCJS OVERHEAD AMBIENT SURROUND LIGHTING LMAS HALOGEN HEADLAMPS
MB1S BLACK FRONT BUMPER MFFS BLACK GRILLE MHBS FENDER FLARES
MMCS   MMGS BELT MOLDINGS MMJS MOLDED-IN-COLOR FENDER FLARES
NAAS FEDERAL EMISSIONS NBAS UNDERGROUND CALIBRATION NBKS SELECTIVE CATALYTIC REDUCTION - WITH
NDAS CATALYTIC CONVERTER NF2S 18 GALLON FUEL TANK QE8S
SCBS STEERING WHEEL SFAS STANDARD DUTY FRONT SHOCK ABSORBERS SGAS STANDARD DUTY REAR SHOCK ABSORBERS
TBCS COMPACT SPARE TIRE TBMS TIRE CARRIER WINCH WJKS 15X6.0 STYLED STEEL WHEELS
WMCS OPEN XBSS PICKUP BOX XFAS -35F PROTECTION ANTI-FREEZE
YAAS BUILD TO U.S. MKT. SPECIFICATIONS Z1AS GVW/PAYLOAD RATING 1AAS U.S. DEALER RETAIL
166S ZONE 66-ORLANDO
On 7/30/2025 at 6:53 PM, The86manche said:
I think I saw a video of this thing moving around. It may even be on here somewhere.
At the very least.. it's still on the ride and alive. So a win. But she R U F F
If you see it again, I'd love to watch it. I didn't find anyone around to ask about it.
Couldn't find the video but here's another post of it with a TikTok link so that should have videos of it.
https://comancheclub.com/topic/59741-just-put-down-the-hammer-and-back-away-slowly/?do=findComment&comment=762582
