Speedomoter
3 hours ago, terryt said:
Finally got my speedometer working perfect
Now when its hot outside the needle is bouncing
But when its cool outside it is perfect any ideas?
1990MJ 4.0 5 Speed
Your inner cable is probably to long. It expands and lengthens when hot. I had the same issue with the cable in my Eagle. I trimmed it down a bit on the end. The issue has gone away.
I don't know if its normal or not, but I can say every xj/mj ive had the speedometer bounces.. I may try Eagles suggestion and trim down the t case side a little bit and see what happens..
