factory style fog lights
Hello, i’m currently running into trouble while trying to install some factory style fog lights, i’ve already bought an OEM harness with fog lights and some HELLA fog lights but I think my issue is the switch. I got a switch from the junkyard but it was for the trans power/comfort and it doesn’t want to turn on at all. Does the switch need to be specifically for the fog lights or is something else the issue?
1 hour ago, Ωhm said:
Headlight SW needs to be ON and set for low beams a
Headlight SW needs to be ON and set for low beams only.
ahhh that explains a lot, I installed some RC led headlights and haven’t gotten around to installing the kit so the low beams aren’t working atm. once they’re up n running the fog lights should start working correctly?
