Twisty Posted January 10, 2008 Share Posted January 10, 2008 So I had a lead on a pair of 1978 Ford D60s but that fell through because the front was bent. I have since aquired a rear FF14b, but am still lacking a front axle. I found a 1979 F250 front D60 on craigslist for $750, and the seller said that the price is negotiable. Here is the email that the seller sent me; It's a recent take off/it has rust on it.I never drove the trk and it's so heavy it really can't be moved around to shake it out.I'm no being vague I just don't know on the king pins.I would recommend going right through it.Before driving it. ie... new fluid,pads,maybe re-cut the rotors,pull the hubs inspect and griese it etc.Yes I am willing to talk on the price,but only in peson. I know there are a few people in here who know much more than me when it comes to 1 tons. Suggestions/comments/recomendations? Link to comment Share on other sites More sharing options...
86FUBAR Posted January 10, 2008 Share Posted January 10, 2008 Hell ya thats a good deal as long as it aint bent and everything looks on the up and up Link to comment Share on other sites More sharing options...
DirtyComanche Posted January 10, 2008 Share Posted January 10, 2008 Decent deal. Any axle that old should be rebuilt anyways. Link to comment Share on other sites More sharing options...
Twisty Posted January 10, 2008 Author Share Posted January 10, 2008 Decent deal. Any axle that old should be rebuilt anyways. Oh definately. I saw a post on Pirate where the upper kingpin had stripped the threads on the inner C, and they guy had to get new ones from Dedenbear. I'm just worying about that. I plan to re-build it completely with new bearings/seals. I just don't want to have to spend $500 for inner Cs or knuckles (at least not now). I think I'll give the seller a ringy ding tomorrow to see about picking it up. Thanks guys. Link to comment Share on other sites More sharing options...
mudhound0530 Posted January 10, 2008 Share Posted January 10, 2008 Is this a good time for me to as what a kingpin is? Ive seen that term thrown around a bit. sorry for hijacking :oops: Link to comment Share on other sites More sharing options...
DirtyComanche Posted January 10, 2008 Share Posted January 10, 2008 Is this a good time for me to as what a kingpin is? Ive seen that term thrown around a bit. sorry for hijacking :oops: Instead of a more typical ball-joints to hold the knuckle on to the axle, king pins are used... They're basically a pin and a set of tapered roller bearings (like wheel bearings) that allow piviting movement, but nothing else. Horrible explaination. But they're often said to be stronger. Which is fair enough, but a big ball joint is strong too (seen on newer D60s). Link to comment Share on other sites More sharing options...
TNT Posted January 10, 2008 Share Posted January 10, 2008 It's a good deal for the early HP D60. It probably has neckdown inner axleshafts FYI. Link to comment Share on other sites More sharing options...
Twisty Posted January 10, 2008 Author Share Posted January 10, 2008 It's a good deal for the early HP D60. It probably has neckdown inner axleshafts FYI. I think that I'll stick with some 37s to 38s with this axle. I'll only upgrade when I break (I drive like an old person). I just called the seller, and it looks like I can pick it up tomorrow for $650 I'm quite ecstatic. Link to comment Share on other sites More sharing options...
Twisty Posted January 11, 2008 Author Share Posted January 11, 2008 1979 high pinion Dana 60 from a Ford F250 Snowfighter. Well I purchased it this morning. It's going to go great with that 14 bolt that I purchased this fall. Link to comment Share on other sites More sharing options...
TNT Posted January 12, 2008 Share Posted January 12, 2008 Nice score. So whats the plan of attack? Link to comment Share on other sites More sharing options...
Twisty Posted January 12, 2008 Author Share Posted January 12, 2008 I want to start simple. 5.13s, spool, kingpin rebuild, hub rebuild, some form of hi-steer. I'll run 38s to start. I don't have a lead foot, so I think that the shafts will last me a while. I'll get alloys at some point though. I also have a 14 bolt rear which will also get 5.13s and a detroit. Before anything, I need to plate the MJ frame with angle iron. I also want to beef up the tracbar and steering box area. I expect to have these under the MJ in a year or two. 8) Link to comment Share on other sites More sharing options...
