Aussiemj Posted January 6, 2025 Posted January 6, 2025 Hi guys What plug in here I think xj it air temp sensor but not sure on a mj Thanks pa
Aussiemj Posted January 6, 2025 Author Posted January 6, 2025 It 1990 comanche 4 liter and I don't have any spare sensor any help would be grateful Paul
Aussiemj Posted January 6, 2025 Author Posted January 6, 2025 Just a quick note this plug is in loom that run on the bottom rail behind the bumper Thanks
Ωhm Posted January 6, 2025 Posted January 6, 2025 Are those fusible links on that harness? If so, should be the Engine Harness. Could be Radiator Temperature SW for cooling fan control (A/C equipped).
Aussiemj Posted January 7, 2025 Author Posted January 7, 2025 Yes it engine harness that run across the bottom radiator rail . I will check colour for fog light Thanks
87MJTIM Posted January 7, 2025 Posted January 7, 2025 There should be two similar connectors, one on each side.
Eagle_SX4 Posted January 7, 2025 Posted January 7, 2025 Quite certain that it is the ambient temp sensor for the overhead console in a XJ. Unless there are 2 of them one on each side for the fog lights. To my knowledge both XJ's and MJ's got the same harness from the bulkhead forward but the MJ got some stuff removed from the cab side. For example XJ's got a low washer light and overhead console with temp but those wires are missing on the MJ. Here is some info on that plug but no pics. Maybe @Automan2164 still has the pic.
