Finally running, sort of
3 minutes ago, eaglescout526 said:
Let’s test the resistance on those sensors when it’s dead cold and see what it sees. There’s a chart somewhere that cruiser would often post. If not I’ll grab a pic later from one of my manuals of the values for certain temps.
Okay. I can wait. It's dark and cold here and I do not have a garage.
22 hours ago, 89 MJ said:
That testing procedure I think was in one of the threads I posted.
Maybe. I didn't see anything that looked right. There are some graphics, but I'm not good all with schematics and electrical diagrams.
I did read that Renix needs to crank around 300 rpm before firing? If that is true, mine is NOT turning over that quickly.
That would tell me that one of three things is happening. Your starter is dying, your battery cables aren’t making a good connection or are inadequate, or your battery doesn’t have enough cranking amps.
I have a charger on it now. I'll let it charge overnight and see what happens in the morning.
What does it say are the Cold Cranking Amps (CCA) of the battery?
CCA 590. Temp this morning is 24 with a 16 wind chill. Charger plugged overnight. Still plugged in, no start, crank is VERY sluggish. The cold is definitely a factor since two weeks ago it was starting and running.
You may want to make a new post about this issue, but I think that should be enough to start it. How do your battery cable ends look both at the battery and at their other ends?
