Aussiemj Posted September 26, 2024 Share Posted September 26, 2024 Hi guys My mj had trims around the front screen. But I am only able get xj rubber and screen with out trim. Do you cut pins away and throw trims in the bin or will trims still fit Paul Link to comment Share on other sites More sharing options...
ghetdjc320 Posted September 26, 2024 Share Posted September 26, 2024 I believe you’re referring to the windshield? If so, the small retaining metal “pins” on the windshield frame can be left in place or removed. The rubber will fit either way. You could also just reinstall your old trim if you wanted. The rubber is not a seal, just a trim piece. The seal itself is made by the urethane. Link to comment Share on other sites More sharing options...
Aussiemj Posted September 26, 2024 Author Share Posted September 26, 2024 Yes the windscreen trim thanks Link to comment Share on other sites More sharing options...
Yellowoctupus Posted October 1, 2024 Share Posted October 1, 2024 Perfect timing for this question, as last week I removed my cracked windshield, and treated some minor rust on the windshield frame. I was under the impression that the 91 and up glass which takes the rubber trim was possibly a larger size than the 84 to 90 glass. I'm indifferent on whether I have the stainless trim or the rubber seal on mine, however was curious what the glass change was between those years. Thank you for verifying that the little weld studs could stay in the frame. Were they taken out of the design after 91? Link to comment Share on other sites More sharing options...
Gjeep Posted October 1, 2024 Share Posted October 1, 2024 The rubber windshield trim happened in 1995+. Link to comment Share on other sites More sharing options...
