Headliner Mounting procedure?
My MJ was missing a headliner. I eventually found one and installed it. However it seems the center rear sags a bit and obstructs the rear glass about 1in. Is this normal? The headliner was not creased or cracked. The rear b-pillars are the only thing that hold in the headliner in the back. Is there some bracket I'm missing? In the photos below I'm holding up the center with my hand in a before / after.
Yep, there is Velcro.  I put a new piece on for freshness on mine.  FYI, I'd you do any butyl mat on the roof, avoid the top center as it will space down the headliner making it more challenging to fit.  As a result of covering my entire roof in Killmat, the headliner now sits forward farther than it should.
This is good to know! I did not have plans to put sound deadening on the inside roof. Tryin to keep my center of mass on the wayyy low :wink:
Gotta put the sport in sportruck :laugh:
Really? Course I only covered the middle sheet metal section and not the cross bars that’s support the roof and other structural parts. But my headliner has no fitment issue.
This was how I did the sound deadening.
