fiddlermj Posted July 9, 2024 Share Posted July 9, 2024 My question is…. Tighten rocker arm bolt to 194 lb? Then 19? On the bolt Link to comment Share on other sites More sharing options...
jdog Posted July 9, 2024 Share Posted July 9, 2024 In lbs or ft lbs? the bolts won't hold at ft lbs Link to comment Share on other sites More sharing options...
The86manche Posted July 9, 2024 Share Posted July 9, 2024 I can imagine it should be inch lbs. You will destroy something at ft lbs Link to comment Share on other sites More sharing options...
fiddlermj Posted July 10, 2024 Author Share Posted July 10, 2024 Ha yes . My wrench does in and ft….but only goes down so far in….inches. Just trying to figure out the initial tightening spec then the check Link to comment Share on other sites More sharing options...
ghetdjc320 Posted July 18, 2024 Share Posted July 18, 2024 19 ft lbs while the valve is closed Link to comment Share on other sites More sharing options...
