1J7GJ26U0LL279726
Wouter
1990, Jeep, Comanche Metric tonne
4.0/ AX15/ NP231/ D30/ D44/ LWB
Build date: 6-90
Current location: The Netherlands
Status: Ongoing project, but running and driving.
Notes: Grey interior, cloth buckets. Hidden winch in front bumper. Dana 30 high pinion non cad in the front, ARB airlocker in the rear, 3.71 gears. 2 inch lift, running on either steelies with 32x11.5's or Icons with 235/85r16's.
Current owner: Me.
BODY: JL62
BUILD: 06/07/90
SELLING DEALER: CHEROKEE EXPORT CO
MIAMI, FL
*X2 DESCRIPTION NOT AVAILABLE -SA CHARCOAL ALA
CBAP STRAIGHT BACK BENCH SEAT CKJP BLACK VINYL FLOOR COVERING DBBC ALL MANUAL TRANSMISSIONS
DDQ 5-SPEED MANUAL TRANSMISSION DRKP REAR AXLE ERB 4.0L I6 MPI ENGINE
GRZP LEFT REMOTE MIRROR GSZP RIGHT REMOTE CONTROL MIRROR GTZ MANUAL REMOTE MIRRORS
JAY DO NOT USE - SEE JP, KA CLASSES JDB 180 KPH PRIMARY SPEEDOMETER JGBP
MBJ BLACK FRONT BUMPER MDA FRONT LICENSE PLATE BRACKET MUXP
NAB LEADED FUEL EMISSIONS NBLP DELETE EVAP CONTROL SYSTEM PB8
SFBP FRONT HEAVY DUTY SHOCK ABSORBERS SGBP REAR HEAVY DUTY SHOCK ABSORBERS TAAC ALL TIRES
TBBP FULL SIZE SPARE TIRE TRPA TIRES WJDP 15X7.0 STYLED STEEL WHEELS
WLYC ALL STEEL WHEELS XKAA EXPORT LABEL YEP MANUF STATEMENT OF ORIGIN
YGAA WITHOUT BILLABLE FUEL Z01P REAR SPRING GROUP I Z5B PAYLOAD RATING - 1800#
Z58P LEFT FRONT SPRING GROUP VIII Z77P RIGHT FRONT SPRING GROUP VII 3D1A INTL. PRICE PROTECTION A
3HL STATESIDE DELIVERY 3HN COSO SBPR-REQUIRED OR UNKNOWN 4HA SPECIAL SCHEDULING CONDITION I
PAS MONOTONE PAINT BAQS 115 AMP ALTERNATOR BCXS Maint. Free Battery
BGAS POWER FRONT DISC/REAR DRUM BRAKES CSRS PASSENGER ASSIST HANDLES CUMS MINI FLOOR CONSOLE
DHNS COMMAND-TRAC PART TIME 4WD SYSTEM DJHS 230MM FRONT AXLE DMMS 3.07 REAR AXLE RATIO
GACS TINTED GLASS WINDOWS GBBS TINTED WINDSHIELD GLASS GCBS FRONT DOOR TINTED GLASS
GEHS FIXED DOOR VENT GLASS GNAS REAR VIEW DAY/NIGHT MIRROR HCDS DO NOT USE - SEE HCA
KWWS   K3ZS STRIPE/BADGE/MOLDING/COLOR LBCS GLOVE BOX LAMP
LMAS HALOGEN HEADLAMPS MB1S BLACK FRONT BUMPER MFFS BLACK GRILLE
MHBS FENDER FLARES MMCS   MMGS BELT MOLDINGS
MMJS MOLDED-IN-COLOR FENDER FLARES NF5S 23 GALLON FUEL TANK QB8S
RA8S DELETE RADIO SBAS POWER STEERING SCBS STEERING WHL
TBMS TIRE CARRIER WINCH XBSS PICKUP BOX YABS BUILD TO EXPORT MKT. SPECIFICATIONS
1AYS EXPORT NON-HOMOLOGATED 107S ZONE 07-EXPORT
20 hours ago, fiatslug87 said:
Interesting that this is a big ton, (G in the 4th position) but the build sheet says it has 3.07 gears.
big ton option didn't affect gear ratio.  4.0+stick = 3.07s. :L:
