EdJarHead Posted June 29, 2024 Share Posted June 29, 2024 Noticed this week my turn signals are no longer working. Fuse panel (photo attached) has been modified by previous owner due to fluid damage, but pretty sure the turn signal fuse is the add on at bottom right in photo. Fuse is good. Hazards work, so I switched the flasher plugs and still nothing (no clicking, no lights). Thinking maybe the switch is bad? Found a post on this, so will try troubleshooting in the next couple days (maybe Monday when it'll be cooler). Anything else I should be looking at? Link to comment Share on other sites More sharing options...
ghetdjc320 Posted June 30, 2024 Share Posted June 30, 2024 Do the blinkers just come on but not flash? Check each bulb and socket. They are a common cause of these sort of issues. Link to comment Share on other sites More sharing options...
jdog Posted July 1, 2024 Share Posted July 1, 2024 Do you have power to the flasher relay? Have you checked it with either a dvom or a test light? Link to comment Share on other sites More sharing options...
EdJarHead Posted July 2, 2024 Author Share Posted July 2, 2024 Another long process for an easy (simple) fix. When I was fixing my radio power, I had disconnected these "add on" fuses, only to realize today that fuses have a positive side and these were put back in upside down/backwards. (I was thinking I was "cleaning up" the wiring to not look so cobbled together). Now I know which (for certain) is the turn signal fuse, but no idea what the 7.5 fuse in the trans slot is powering (both have 2 black/yellow wires). Link to comment Share on other sites More sharing options...
Ωhm Posted July 2, 2024 Share Posted July 2, 2024 Good find on your add-on fuses. TCU 7.5A fuse is for Backup Lamps. Link to comment Share on other sites More sharing options...
