DirtyComanche Posted January 5, 2008 Share Posted January 5, 2008 Some might be interested, just a short little clip. I don't think it's a repost. http://www.brightcove.tv/title.jsp?titl ... =140859702 Link to comment Share on other sites More sharing options...
Pete M Posted January 6, 2008 Share Posted January 6, 2008 Sweeeeeeet! Link to comment Share on other sites More sharing options...
jtdesigns Posted January 6, 2008 Share Posted January 6, 2008 Were those mj's in the road race ifs?? They had some major negative camber going on.. Has neone ever put a ifs sub frame in a mj?? Link to comment Share on other sites More sharing options...
DirtyComanche Posted January 6, 2008 Author Share Posted January 6, 2008 There's an IFS MJ on here, JBhill's truck... Those are SFA though. The use a 2wd beam. I think they used adjustable ball joints. The SCCA rules didn't allow major modifications to the trucks AFAIK. Link to comment Share on other sites More sharing options...
feerocknok Posted January 6, 2008 Share Posted January 6, 2008 B!tchin. Link to comment Share on other sites More sharing options...
jtdesigns Posted January 6, 2008 Share Posted January 6, 2008 I found a few things from him. I saw his truck tucked with big wheels but none showing the ifs... :cry: edit : http://www.comancheclub.com/forums/viewtopic.php?t=1253&highlight= Link to comment Share on other sites More sharing options...
feerocknok Posted January 6, 2008 Share Posted January 6, 2008 I found a few things from him. I saw his truck tucked with big wheels but none showing the ifs... :cry: edit : http://www.comancheclub.com/forums/viewtopic.php?t=1253&highlight= http://www.comancheclub.com/forums/view ... highlight= http://www.comancheclub.com/forums/view ... highlight= http://www.comancheclub.com/forums/view ... highlight= Not sure if any of those show the suspension, but those are his project threads. And he's got one pic on his myspace page as well of it, if you have myspace. Link to comment Share on other sites More sharing options...
jtdesigns Posted January 6, 2008 Share Posted January 6, 2008 I found a few things from him. I saw his truck tucked with big wheels but none showing the ifs... :cry: edit : http://www.comancheclub.com/forums/viewtopic.php?t=1253&highlight= http://www.comancheclub.com/forums/view ... highlight= http://www.comancheclub.com/forums/view ... highlight= http://www.comancheclub.com/forums/view ... highlight= Not sure if any of those show the suspension, but those are his project threads. And he's got one pic on his myspace page as well of it, if you have myspace. Thanks bro,, I found the first one,, I'm still missing alot of fab work on the truck.... like floors and how he tied that frame into the cab... I have lots of s10 parts... 2 or 3 frames too...... nah... to much work... Hey dirty I found some zj rear springs, I'm going to throw them in my mj I'll let you know how much a drop it is... Did that guy ever say what year his springs came out of? Link to comment Share on other sites More sharing options...
DirtyComanche Posted January 6, 2008 Author Share Posted January 6, 2008 Hey dirty I found some zj rear springs, I'm going to throw them in my mj I'll let you know how much a drop it is... Did that guy ever say what year his springs came out of? Which guy? And I THINK you'll be at about a 3" drop with ZJ rears? The ZJ guys put their stock fronts in the rear to give them about 3" of lift, IIRC. Clearances with the oil pan get bad at about 3" low in the front, I think. I'm sure it can be fixed, but everyone I've ever talked to about it seemed to think it was a 'major' problem. :nuts: I think they just aren't willing to use a sawzall. Link to comment Share on other sites More sharing options...
jtdesigns Posted January 6, 2008 Share Posted January 6, 2008 Hey dirty I found some zj rear springs, I'm going to throw them in my mj I'll let you know how much a drop it is... Did that guy ever say what year his springs came out of? Which guy? And I THINK you'll be at about a 3" drop with ZJ rears? The ZJ guys put their stock fronts in the rear to give them about 3" of lift, IIRC. Clearances with the oil pan get bad at about 3" low in the front, I think. I'm sure it can be fixed, but everyone I've ever talked to about it seemed to think it was a 'major' problem. :nuts: I think they just aren't willing to use a sawzall. :eek: I think it was a few back in that sports truck thread... I can't remember, but it was recently cause it was fresh on my mind when I ran into this guy lifting a zj. anyhoot, yeah I can see a issue with clearance right there. but hey the oil pan is metal so it can be welded.. I don't know how the oil level would be compensated if you notched it though. I would like to know how those SCCA trucks were set up. Link to comment Share on other sites More sharing options...
DirtyComanche Posted January 6, 2008 Author Share Posted January 6, 2008 They're all 2.5s, so they don't have as many clearance problems. With a 4.0L the oil pan is lower... Also the UCA towers on the axle hit the oil pan flange. Again, that can be fixed. Notching an oil pan for clearance is nothing new though. Look at the oil pan in a 6cyl IFS toyota truck if you want a really good example! Link to comment Share on other sites More sharing options...
