What the hell is this
Yes I think that was to the oil pressure gauge (installed before I bought the truck) as it’s not working now. Does anyone have a thread on upgrading the gauge cluster? The gauges are the one thing I really don’t like about the xj/mj and id really like to have something like what a tj has.
Year would help us but if youre MJ has Renix, an idiot light cluster or a gauge cluster is all you get. HO its "digital" but only the speedo and tach are. HO XJ Gen II swap would yield you the cluster you want but you have to do a whole interior swap to 97-01. Both HO swaps require you to change the engine management.
As far as the clusters being "good", clean the grounds and all the connections at both the sensors and cluster and it should read pretty accurately. Aftermarket sensors are known to be off about 10-20% in accuracy. Mopar still makes the oil sensor but not the temp.
