fiatslug87 Posted May 24, 2024 Posted May 24, 2024 CRUISER'S MOSTLY RENIX TIPS THROTTLE BODY TO MAP SENSOR HOSE FIX The Renix throttle bodies have a strange and failure prone connector on the side where the MAP supply originates and then runs up to the MAP sensor located on the firewall. This hose/pipe assembly is no longer available for purchase. The real kicker here is how critical this line is in supplying the correct vacuum signal to the MAP, the most relied upon sensor for the ECU to read regarding air/fuel ratio. Any cracks, melted spots, or loose rubber connectors can cause major starting and driveability issues. There’s a simple fix though. All that’s required is a 1/8” NPT tap, a new throttle body gasket ( Napa FPG 60742 ), a vacuum fitting (Napa 05703-B102), two vacuum elbows (Napa CRB2670), and a length of new plastic piping (Napa CRB2672). Remove the throttle body and take it to the workbench. Using an oiled tap along with a driver, carefully thread the lower of the 2 holes of the throttle body where the old fitting was plugged in. Don’t go too deep. These are pipe threads. Flush the hole with carb cleaner and inspect for any left over cuttings. This is an excellent time to do a complete throttle body and IAC cleaning. See Tip 11. Take the vacuum fitting (05703-B102 ) and apply a LITTLE bit of thread sealer on the threads only. I prefer Permatex #2 but almost anything is fine. Carefully screw the fitting in until snug. Install one of the vacuum elbows on the MAP sensor so it points toward the throttle body, and the other vacuum elbow on your new throttle body fitting so it points up to the MAP sensor. Cut a length of the new plastic tubing (approximately 13 inches) to fit between the vacuum elbows and install it making sure there is enough slack for some engine movement. Route it according to the photo. We don’t want any rubbing or chafing with engine movement. Not a bad idea to use some contact cement or Gasga-Cinch sparingly on the tubing to elbow connectors. Revised 2-06-2016
OzarkGuy Posted July 8 Posted July 8 Does anyone have updated part numbers for the above? These numbers do not show up on Napa online
Eagle_SX4 Posted July 8 Posted July 8 Here you go. Looks like napa updated their part numbers and removed the dashes. Elbow, CRB 2670 Vacuum hose, CRB 2672 Brass fitting, WH 05703B102
AnotherOldJeepGuy Posted July 13 Posted July 13 Got the elbow and the brass fitting, hose didn't make it in. Just noting that pressing the elbow on to the brass fitting takes a low of elbow grease. I haven't tried that connecting at the MAF yet, I hope it's a little less tight. Might be time for a bit of vasoline.
OzarkGuy Posted July 15 Posted July 15 Thanks for the updated numbers. All ordered. Throttle body is tapped and threaded.
AnotherOldJeepGuy Posted July 15 Posted July 15 Good luck! Post how it turns out with pics! I'm curious if your elbow part is as tight as what I just got at the brass fitting, can just barely get it on there (meaning it is so tight I am a bit concerned how long is will last without splitting). Haven't tried it at the MAF end yet.
OzarkGuy Posted July 21 Posted July 21 Yes, the rubber nipple was tight. Put a dab or grease and I mean a hint! Working on interior as I am A.D.D. and can't sit still at one aspect.
Liam Williams Posted Thursday at 05:59 PM Posted Thursday at 05:59 PM The tightness at the brass fitting would concern me too, especially if it needs to hold up long term. A hint of grease on the rubber nipple sounds like a sensible approach, since it should help without compromising the grip. Curious whether the MAF end goes on easier or if it's just as snug. Looking forward to seeing how it holds up once it's all buttoned together.
