Need help identifying this wiring harness connector
I'm trying to reinstall the dash back in my '87 Comanche after changing out the Evap and heater cores.  I thought I took enough pictures to assure getting everything back connected but am at a loss for this one connector.  This part of the harness comes into the passenger compartment through the firewall just to the right of the engine and in the same vicinity as the AC and Heater connections.  I looks like it is supposed to be routed around to the left towards the steering column but I am not sure.  Perhaps it is an accessory harness that is not used on my Comanche?  Any help identifying this would be greatly appreciated.20240523_120442.jpg.79095349d30884b33bd9cd1157746180.jpg20240523_120534.jpg.1dd705dfe310cc4fdcb3da55ad1460e4.jpg
Please put your truck's information in your signature. For example: year, engine, transmission, 2wd/4wd, short bed, long bed, Base/Pioneer/Laredo/Chief.  It will help us answer your questions.
As EagleScout526 was saying, that is the transmission computer connector.
TCU connection:
My truck does have an automatic trans and should know where the TCU is located.  I probably did at some point but my 75 years are beginning to play havoc with my memory.  Can you give a the general location of the TCU?
1987, 4.0, 4wd, Shortbed, AT.
Funny, I see it was there.
