colthrax Posted May 8, 2024 Share Posted May 8, 2024 What is the ohm range is the fuel level sender using? is it the same for XJs? Link to comment Share on other sites More sharing options...
87MJTIM Posted May 8, 2024 Share Posted May 8, 2024 It depends... Renix or HO? Link to comment Share on other sites More sharing options...
colthrax Posted May 8, 2024 Author Share Posted May 8, 2024 Both if you know them, Forgot if I have the sender from a renix or HO. Got a XJ tank but maybe MJ pump. 2 years since i did it but need to program my dash. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted May 8, 2024 Share Posted May 8, 2024 The high output sending unit I tested was .5 ohms full and 108 ohms empty. It came out of a 94 XJ. Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 8, 2024 Share Posted May 8, 2024 I’m pretty sure Renix is 0-88 ohms Link to comment Share on other sites More sharing options...
colthrax Posted May 9, 2024 Author Share Posted May 9, 2024 18 hours ago, eaglescout526 said: I’m pretty sure Renix is 0-88 ohms This seems to look alright, so I think I still have the renix sender in the XJ tank. Thanks :) Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 9, 2024 Share Posted May 9, 2024 No problem! Link to comment Share on other sites More sharing options...
