Smokeyyank Posted January 23, 2024 Share Posted January 23, 2024 I think I know the answer, but want to get some opinions. This is part of my builder HP44 front axle. I found a great deal on some new bead locks (~$200each) but they are 6x135 bolt pattern. I've gathered a few parts for the front to run the chevy 6 spindle but that stock bolt pattern is 6x139.7. I'm wondering if I can just redrill the hubs and rotors or do I need to something else? Other though it just an adapter but not as keen on those. Link to comment Share on other sites More sharing options...
89 MJ Posted January 23, 2024 Share Posted January 23, 2024 I could be wrong, but I do not think adapters are made to go from a larger bolt pattern to a smaller one (6x139.7 to 6x135), but I could be wrong. I have no idea on redrilling hubs and rotors, but I wouldn't do it to one of my vehicles. It makes it take so much longer if these parts need to be replaced. Link to comment Share on other sites More sharing options...
Ace Comanche 89 Posted January 23, 2024 Share Posted January 23, 2024 They make adapters for that you can buy. Especially since you’re not changing much size. I have 5x5.5” to 5x5 adapters Link to comment Share on other sites More sharing options...
Smokeyyank Posted January 23, 2024 Author Share Posted January 23, 2024 I found these and a few others. https://venumwheel.com/products/gm-6x5-5-6x139-7-mm-to-ford-6x135-mm-black-hub-centric-wheel-adapters I was dabbling around some more and found I could use later f150 rotors and calipers that are the 6x135. I would just have to redrill the hubs and then fab/find a caliper bracket. That wouldn't be my first choice but would be the smartest. I'm going to keep looking around and see. Link to comment Share on other sites More sharing options...
75sv1 Posted January 24, 2024 Share Posted January 24, 2024 I wouldn't see an issue with drilling another set of 5 on 5???. I might have to do that with the rear axle shafts on an XJ with Ford 8.8. The Yukon axles come with 5 on 4.5 and 5 on 5.5. Either drill the rear axles, or come up with 5 on 5.5 hubs for the front. And also, 5.5 rims. Link to comment Share on other sites More sharing options...
Smokeyyank Posted January 24, 2024 Author Share Posted January 24, 2024 2 hours ago, 75sv1 said: I wouldn't see an issue with drilling another set of 5 on 5???. I might have to do that with the rear axle shafts on an XJ with Ford 8.8. The Yukon axles come with 5 on 4.5 and 5 on 5.5. Either drill the rear axles, or come up with 5 on 5.5 hubs for the front. And also, 5.5 rims. I'll be running custom rear shafts because of the 35 spline. It's the front that I'm trying to sort out. Since I have to get custom shafts regardless I wasn't trying to find a certain bolt pattern. Was more so seeing what wheels I could get the cheapest and go from there. Link to comment Share on other sites More sharing options...
