hsifgod Posted January 17, 2024 Share Posted January 17, 2024 I'm working on collecting parts to eventually upgrade my '86 Comanche to a straight 6 and I was wondering on the subject of the Np242 transfer case if one out of a Durango would have the same spline count and in general what ones I should look for to put in it I'm going with a 94 or newer manual AX 15 transmission Link to comment Share on other sites More sharing options...
gogmorgo Posted January 18, 2024 Share Posted January 18, 2024 Can you not find one for a Jeep? Any 242 behind a ‘91+ AW4 in an XJ or the ZJ’s 46RH should have the correct input gear for use with an AX15, although it’s always best to double check before you bolt things together. If you’re using a ‘97+ XJ you’ll need a compatible driveshaft yoke for the sealed output. I don’t know much about the Durango or whether it’s transfer case would work with the AX15. Link to comment Share on other sites More sharing options...
Andy in Pa Posted January 18, 2024 Share Posted January 18, 2024 I believe all the t-cases that went behind an AX-15 were 23 spline. So when you are sourcing the 242 t-case, just make sure it has a 23 spline input. A. Link to comment Share on other sites More sharing options...
acfortier Posted January 18, 2024 Share Posted January 18, 2024 Images are broken, but here's someone talking about the NV231 and NV242 from a Durango: https://www.jeepforum.com/threads/dodge-242-d-hd-231-d-hd-transfer-case-options.2142057/ Link to comment Share on other sites More sharing options...
hsifgod Posted January 19, 2024 Author Share Posted January 19, 2024 I found a few that were out of Jeeps The problem was is they were all quite a ways away and or nobody wanted to respond but the information that I have gotten here is extremely helpful I believe I have found one it's out of a 2002 grand Cherokee Link to comment Share on other sites More sharing options...
gogmorgo Posted January 19, 2024 Share Posted January 19, 2024 The other consideration with the later tcase is whether or not they’ll have accommodation for your speedometer. Link to comment Share on other sites More sharing options...
hsifgod Posted January 19, 2024 Author Share Posted January 19, 2024 On the speedometer part I was thinking about either using a GPS speedometer if I had to or if I find the one that I'm looking for if it has the speedometer gear mount using that so I think I'm good on the speedometer part Link to comment Share on other sites More sharing options...
speeding_infraction Posted January 19, 2024 Share Posted January 19, 2024 Where are you located? I have an AX15 that needs new synchros and an np231j tcase if your interested. Are you in the pnw? Link to comment Share on other sites More sharing options...
hsifgod Posted January 19, 2024 Author Share Posted January 19, 2024 I'm from Northwest Missouri I'm not sure what you mean by PNW Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 19, 2024 Share Posted January 19, 2024 1 minute ago, hsifgod said: PNW Pacific North West Link to comment Share on other sites More sharing options...
hsifgod Posted January 19, 2024 Author Share Posted January 19, 2024 That makes sense I don't know why I didn't put that together Link to comment Share on other sites More sharing options...
speeding_infraction Posted January 19, 2024 Share Posted January 19, 2024 16 hours ago, hsifgod said: I'm from Northwest Missouri I'm not sure what you mean by PNW Ok nevermind then. Good luck on your search Link to comment Share on other sites More sharing options...
hsifgod Posted January 21, 2024 Author Share Posted January 21, 2024 I greatly appreciate the offer though Link to comment Share on other sites More sharing options...
