Hi all,
I'm new to the forum, but I wanted to share my project comanche. It is a 1990 big ton that I picked up before the pandemic for $400. I also got a running 1994 cherokee as a donor vehicle that had a bad t-case. Found a shell for $75 bucks. I pulled the motor out of the cherokee, did the lower end bearings, a quick hone on the cylinders and put in new rings. I will be moving this into the garage this winter to get it started and fix a questionable SOA lift that the previous owner did.this is going to be a big project and I will need to source some missing comanche specific parts, but I am excited to finally get this going
