1J7FJ36B7KL541921
fiatslug87
BODY: JM62
BUILD:03/03/89
SELLING DEALER: AUTO FENNICA OY
HELSINKI, EX
FINLAND
Well what do ya know, it actually pulls up and is actually from Finland.  A lot of new codes we have not seen before and a lot of codes that I bet are correct.
but usual disclaimer of who knows what Chrysler did and what is actually correct.
*X1 DESCRIPTION NOT AVAILABLE -Q8 DESCRIPTION NOT AVAILABLE CBAP STRAIGHT BACK BENCH SEAT
DBBC ALL MANUAL TRANSMISSIONS DDQ 5-SPEED MANUAL TRANSMISSION EAAC ALL ENGINES
EADC ALL DIESEL ENGINE ENA DESCRIPTION NOT AVAILABLE GEC FRONT LEFT SIDE SLIDING WINDOW
GFD REAR SLIDING WINDOW GRCP ENTIRE FLEET KEY ALIKE (FREQ 7) JGBP
JHA VAR INTERMITTENT WINDSHIELD WIPERS MDA FRONT LICENSE PLATE BRACKET MUXP
PB3 INTENSE BLUE PEARL COAT RAAC ALL RADIO EQUIPPED VEHICLES RCAP
SUA TILT STEERING COLUMN TAAC ALL TIRES TAEA TIRE SIZE:TBD
TBB FULL SIZE SPARE TIRE TRN P225/75R15 OWL WRANGLER AT TIRES WJM 15X7.0 CHROME WHEELS
XKAA EXPORT LABEL XPB UNDERCOATING XPF PROTECTIVE COATING AND REMOVER
YGAA WITHOUT BILLABLE FUEL Z01P REAR SPRING GROUP I Z66P LEFT FRONT GROUP XV
Z84P RIGHT FRONT SPRING GROUP XIII 3HMA COSO SPBR NOT REQUIRED 4EA SOLD VEHICLE
4XT DELETE DOMESTIC WARRANTY MANUAL 5AMA JF/3450 VEHICLE FAMILY 8CA FINLAND COUNTRY CODE
APAS MONOTONE PAINT BABS 160 AMP ALTERNATOR BCRS ALLIANCE BATTERY CODE-DO NOT USE
BGAS POWER FRONT DISC/REAR DRUM BRAKES BJAS DESCRIPTION NOT AVAILABLE BKPS 10X2.5 REAR DRUM BRAKES
CKAS CARPETS - FLOOR AND CARGO AREA CSRS PASSENGER ASSIST HANDLES CUMS MINI FLOOR CONSOLE
CXDS TRIM PARTS DHNS COMMAND-TRAC PART TIME 4WD SYSTEM DJHS 230MM FRONT AXLE
DMFS 4.10 REAR AXLE RATIO DRJS DANA 35 REAR AXLE GACS TINTED GLASS WINDOWS
GBBS TINTED WINDSHIELD GLASS GCBS FRONT DOOR TINTED GLASS GNAS REAR VIEW DAY/NIGHT MIRROR
GUBS MIRRORS-BASE HCDS DO NOT USE - SEE HCA HGAS HOOD INSULATION
JAAS INSTRUMENT PANEL JAYS DO NOT USE - SEE JP, KA CLASSES JBDS INSTRUMENT PANEL SATIN SILVER BEZEL
JDBS 180 KPH PRIMARY SPEEDOMETER JJAS CIGAR LIGHTER JKBS
KKES DESCRIPTION NOT AVAILABLE K2XS STRIPE/BADGE/MOLDING/COLOR K3BS STRIPE/BADGE/MOLDING/COLOR
LAFS SEAT BELT ALERT-DRIVER SEAT ONLY LBCS GLOVE BOX LAMP LCJS OVERHEAD AMBIENT SURROUND LIGHTING
LMAS HALOGEN HEADLAMPS MBJS BLACK BUMPER MB1S BLACK FRONT BUMPER
MFGS BODY COLOR HEADLAMP BEZELS MHAS BLACK WINDSHIELD MOLDINGS MMCS
MMGS BELT MOLDINGS MMKS   NBAS UNDERGROUND CALIBRATION
NBLS DELETE EVAP CONTROL SYSTEM NDBS DELETE CATALYTIC CONVERTER NF5S 23 GALLON FUEL TANK
NHKS ENGINE BLOCK HEATER NZAS DIESEL EMISSIONS QB3S INTENSE BLUE PEARL COAT
RACS OPEN SBAS POWER STEERING SCES STEERING WHEEL
SFAS STANDARD DUTY FRONT SHOCK ABSORBERS SGAS STANDARD DUTY REAR SHOCK ABSORBERS TBMS TIRE CARRIER WINCH
XBSS PICKUP BOX XFAS -35F PROTECTION ANTI-FREEZE YABS BUILD TO EXPORT MKT. SPECIFICATIONS
Z5AS GVW/PAYLOAD RATING 1AYS EXPORT NON-HOMOLOGATED 106S ZONE 06-EXPORT
