Looking for an "e" that goes on the front of the jeep above the Grille. Mine is missing a stud on the rear and was glued on.
Picture showing what I need and the broken bit.
I found one. It’s new, I highly don’t recommend trying to reuse the original nut that was on, I broke a new set trying to reuse the nut that holds them in place. I’d try to use one of those clips that hold the salve cylinder in place on the manual transmissions.
Hummm sorry, as I don't want to divert the thread, but curiosity got the best of me! What year/model got those kind of letters? All the XJs/MJs I saw had stick-on letters and no holes in the header panels?
The bolt on letters were used through 1992.  Stick on after that.
Interesting! That means my '88 doesn't have its original header panel...
On 11/26/2023 at 2:31 PM, eaglescout526 said:
Don’t forget. 84-87 got brushed letters and 88-90 got just smooth polished letters. Which all I have are brushed letters.
I'm gonna need the smooth ones, mine is a '92. Glad you mentioned that, didn't know there was a difference.
1 minute ago, Tex06 said:
mine is a '92.
Interesting. Someone swapped the header on yours if it wasnt you. Late 91-92 used just a stick on letter set.
That being said, I have a smooth "e", its NOS, not sure if you want to go that route.
Yeah, it was wrecked previously. Now that I think about it, the front bumper says "90 Comanche" inside it in typical junkyard paint pen.
I'll take it, PM incoming.
