Remim Posted November 22, 2023 Share Posted November 22, 2023 Greetings from Finland. I have been trying to find a starter motor for my Jeep Comanche. The engine is J8S 814, 2.1l turbo diesel. So does anyone know the part number and is the Renault and Jeep Cherokee starter motor the same. As long as the engine is 2.1l td. I have found a starter motor of an older model, but I don't dare to order because I don't know if it fits. Mine is from 1991. I tried to search the forum for information on the subject, but could not find it. Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 22, 2023 Share Posted November 22, 2023 You have an 91 with the Renault 2.1L? AMC dropped the 2.1L in the Jeep line up in 86. Youre in a better position than us in the states as that engine is more common over there than it is here. I can’t imagine you would be having issues locating a starter. I can look in my parts manual in the morning and post it here later, but it will be an AMC number and not a Renault one…..actually it might be a Renault number. I’d have to look. And yes the Cherokee also had the Renault 2.1L from 84-86. Link to comment Share on other sites More sharing options...
Remim Posted November 22, 2023 Author Share Posted November 22, 2023 Thanks you. Yes it is whit that engine. Surprisingly bad market around here. For certain parts. Only a handful of this model have been brought here. 41 minutes ago, eaglescout526 said: You have an 91 with the Renault 2.1L? AMC dropped the 2.1L in the Jeep line up in 86. Youre in a better position than us in the states as that engine is more common over there than it is here. I can’t imagine you would be having issues locating a starter. I can look in my parts manual in the morning and post it here later, but it will be an AMC number and not a Renault one…..actually it might be a Renault number. I’d have to look. And yes the Cherokee also had the Renault 2.1L from 84-86. Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 22, 2023 Share Posted November 22, 2023 Doesn’t seem right that you have a 91 with a 2.1L unless someone swapped it. Are you sure it’s not the 2.5L that Chrysler used? The Renault 2.1L start motor numbers 8982775042 or 82775042 8953002577 or 53002577 Link to comment Share on other sites More sharing options...
Remim Posted November 22, 2023 Author Share Posted November 22, 2023 Thank you. I start looking the part whit those numbers. I am absolutely sure about the engine. The code J8S 814 can be found in the block. The year model of the car may be wrong. According to state information, it would be 1991. But I looked at the vin number, so it seems to be 1989 based on that. Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 22, 2023 Share Posted November 22, 2023 Interesting. Okie dokie For the start of the last 8 of the VIN is the year GT-86 HT-87 JT-88 KL-89 LL-90 ML-91 NL-92 Would be an interesting swap if that’s the case. You can also post your VIN in the registry to get a build date and sheet. Link to comment Share on other sites More sharing options...
Remim Posted November 22, 2023 Author Share Posted November 22, 2023 1J7FJ36B7KL541921. So it is 1989 Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 22, 2023 Share Posted November 22, 2023 An 89 with a 2.1L. Whadda ya know. Link to comment Share on other sites More sharing options...
fiatslug87 Posted November 22, 2023 Share Posted November 22, 2023 @Remim create a post in the Registry with VIN as the title to get the info. https://comancheclub.com/forum/32-1989/ Link to comment Share on other sites More sharing options...
Remim Posted November 22, 2023 Author Share Posted November 22, 2023 43 minutes ago, eaglescout526 said: An 89 with a 2.1L. Whadda ya know. With turbo and intercooler. 5 speed manual and 4wd Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 22, 2023 Share Posted November 22, 2023 Yeah the turbo, intercooler and the 5 speed is the only configuration it came. I think 4wd was optional with the engine but don’t quote me on that. Link to comment Share on other sites More sharing options...
ThreeComanches Posted October 12, 2024 Share Posted October 12, 2024 Are you still looking for a starter motor? if so, I might have a spare I could part with. Link to comment Share on other sites More sharing options...
