NHMJXJ Posted September 25, 2023 Share Posted September 25, 2023 'tis inspection time and I knew I was going to have to repair a hole in the floor of my XJ. Thought I might get away with another patch, but, not so much. Can someone recommend a source for a passenger floor pan for my '01 XJ? Link to comment Share on other sites More sharing options...
eaglescout526 Posted September 25, 2023 Share Posted September 25, 2023 Washer and dryer panels. Thicker than normal sheet metal and are already coated. Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted September 25, 2023 Share Posted September 25, 2023 Something to note. I replaced my floor pan with one from C2C fabrication. They claim "made in the motor city" on all their products. The pan was made in Taiwan by CHL I can't say 100% if it's the same as the keyparts one but it looks very similar. I also grabbed one from advance auto parts. It was another pan made in Taiwan by CHL Link to comment Share on other sites More sharing options...
Pete M Posted September 25, 2023 Share Posted September 25, 2023 key parts should have it. check ebay Link to comment Share on other sites More sharing options...
Keyav8r Posted September 28, 2023 Share Posted September 28, 2023 Where can you get the plugs/caps/whatever for the holes? I may be lucky enough to get another Comanche one day and I’m 97.5% sure it will need floor work. Link to comment Share on other sites More sharing options...
Pete M Posted September 28, 2023 Share Posted September 28, 2023 can't remember about the big one, but I'm using generic grommets I found online for the others. Link to comment Share on other sites More sharing options...
