Renix Vacuum Canister OEM Location
I've been looking around on ebay listings and in the jeep service manual and everywhere I could find mentions the vacuum canister is screwed to the front bumper. Mine is not. My front bumper has no holes in the front face to mount it. Instead, my vacuum canister is bolted into one of the side A-shaped fender brackets behind the bumper. It is held on with one of the two mounting bolts. That seems like a recipe for failure if I leave it mounted this way.
If anyone has photos from their renix comanche vacuum canister, I'd appreciate it!
Maybe I should just move it below the coolant expansion tank :L:
20 minutes ago, fiatslug87 said:
That diagram is incorrect. The holes are on the underside of the bumper, the two hex head bolts.
Thanks a ton for this! I repainted my bumper and assembled everything and I was wondering what the slots on the bottom were for! I thought my bumper was after market and the front holes were just missing. Thanks again!
17 minutes ago, eaglescout526 said:
Does this question pop up a lot?
Never underestimate the power of an incorrect diagram! :roflmao:
